Results 1 to 8 of 8
Need to get my 1st Gen SV 650 looked at before Tony's on the 17th/18th
    May 2012
    I was at BOMO yesterday. Bike was backfiring like crazy and it stalled in turn 3. (I had put in fresh gas and it was running fine at Tony's on May 21st.)
    I called Seacoast, Souhegan, and Plaistow. Seacoast said they could take a look Saturday morning but if it is anything that requires more than about an hour of work then they won't have time to fix it.
    The other two were booked.
    I'm still learning how to to work on my bike and do not want to start taking things apart so close to a track day.
    Can anyone recommend a shop that would work on an SV and be able to have it ready for Monday? Otherwise I'll bring it to Seacoast on Saturday and hope it is something simple.
    Thanks.
    Re: Need to get my 1st Gen SV 650 looked at before Tony's on the 17th/18th
    Call tony Martin at the pit stop in New Bedford. He has a dyno too, so he can get that thing purring efficiently at the same time.
    Worst case scenario, come up the night before, bring some snacks & a couple 6 packs & we'll dive into it.
    Adrenaline Cycles in swansea should be able to sort you out. give them a call
    Check the plugs. I would change them either way though with NGK CR9E plugs.
    that guy darkduc7's Avatar
    Apr 2010
    Georgia, VT
    I'd check the coils and connections. OR for water down the spark plug hole front cylinder, but only if you've ridden in the rain.
    I know you said you don't wanna work on your bike. But if a buddy tears into it, have him check those things as well as plugs like chuck said.
    CCS/LRRS EX #226
    LOW DOWN RACING
    Current stable:
    2008 hyper 1100
    2007 crf450r
    2009 yz450f
    2008 sikk mx 125 minimoto
    Rick Claxton in Salisbury. Used to be with G&G Cycles. 978-961-0475.
    Go fast. Have fun. Repeat.
    May 2012
    Thanks everyone. I just dropped the bike off with Justin at Adrenaline Cycles
  1. Corner Working, May 17th and/or 18th
    By Stoneman in forum Pit Area
    Last Post: 05-08-03, 09:47 AM
