Results 1 to 18 of 18
Autozone oil deal
    Old School Fool. ZX11D's Avatar
    Jan 2009
    Wilmington MA
    Autozone oil deal
    ALL MOTORCYCLE OIL. $2.00 off each . Example
    Castrol 4. T full synth 12.99 @ cycle gear
    9.99 @ Auto zone with deal 7.99 qt. if you don't see it they will order it. I'm stockin up dude!
    Lifer Stromper's Avatar
    Eastern Ct
    Re: Autozone oil deal
    Unfortunately
    Here in the USA there is NO REAL SYNTHETIC produced by the majors Mobil1, Castrol, Valvolene all whats called purified and reformated dyno oil Group 3
    Not crap but NOT synthetic as a designed molecule as in PAO* or Ester based.
    Amsoil, Redline, some motuls are true synthetics
    * The original PAO (poly alpha olefin I think) was this cool fork shaped molecule that when under load the forks would tangle so it had great film strength but would flow. Dyno oil can be anything but most alkanes are just long mostly straight chains, and you don't get the fork.
    I make my own synthetic blend for the street bike like 1/3 redline and the rest bogus synthetic Rotella Diesel Oil, I did maintain good shifting for 5000 miles and it came out clear as a bell
    The calculus of hate
    Central VT
    .........and it came out clear as a bell
    Srsly?
    Jake
    2006 ZX-10R
    1999 Kawasaki ZRX1100
    Jan 2009
    Wilmington MA
    Huh?
    Jan 2012
    Lowell
    If you want true synthetic for cars from castrol get the 0 30 made in Germany. Look at the back of the bottle and it will say made in Germany instead of made in the USA.
    Shell T6 at Tractor Supply, $19.99 for 4 quarts...less if you buy it by the 2.5-5 gallon buckets
    I've only a few words for the full synthetic..... want vs need
    Jan 2009
    Wilmington MA
    Quote Originally Posted by shortbus View Post
    Interesting. I never ever thought any further than getting what i thought was good oil. I guess there is a bit more to it.
    Jan 2012
    Lowell
    http://www.supramania.com/forums/sho...and-Synthetics
    and
    http://www.mkiiitech.com/forum/showthread.php?t=869
    That "guide" is a bit out of date at this point but it highlights a lot of basics in an easy way to understand, the second link explains how in the USA you can sell a synthetic that is not a true synthetic.
    API Base Stock Groups:
    Lubricant base stocks are categorized into five groups by the API:
    Group I base stocks are composed of fractionally distilled petroleum which is further refined with solvent extraction processes to improve certain properties such as oxidation resistance and to remove wax. These oils are no longer very common and should never be used in an automotive engine.
    Group II base stocks are composed of fractionally distilled petroleum that has been hydrocracked to further refine and purify it. These oils comprise many of the single grade motor oil you see on the shelf.
    Group III base stocks have similar characteristics to Group II base stocks, except that Group III base stocks have higher viscosity indexes. Group III oils are produced by further hydrocracking of Group II base stocks, or of hydroisomerized slack wax. Manufacturers label Group III oils as standard motor oil or as synthetic in the US for marketing purposes. It depends on the level of refinement and additive pack. The ACEA in Europe does not allow a Group III oil to be labeled as “synthetic”.
    Group IV base stocks are polyalphaolefins (PAO). These were the 1st synthetic oils produced.
    Group V is a catch all group for any other synthetic base stocks. Examples of Group V base stocks include polyol esters (POE), polyalkylene glycols (PAG oils), and perfluoropolyalkylethers (PFPAEs). In addition, base stocks using Fischer-Tropsch-synthesis (gas-to-liquid) fall in this group.
    POE oils are the most common Group V oils (Red Line for example), in fact, POE oils are used for lubrication in jet turbines and are some of the best oils available. All the Group V oils represent the latest in petroleum technology. But, just because oil is classified as Group V doesn’t mean that it’s better….Group V oils are simply synthetics that are not PAO based.
    Natick
    Wirelessly posted
    They also have rotella T6 on for.$5 off a jug...great for turbo cars.
    Jan 2009
    Wilmington MA
    My Audi is spposed to run sythetic oil (2.0 turbo) i use Castrol for that . I wonder if I am using the right oil? Could it void my warranty? Is this the beginning of the can of worms? Oh boy!
    I93/495
    It's Spring. Way to late for a winter style oil thread.
    Natick
    Wirelessly posted
    Castrol.syntec I hope. My two audis I used 10w 40 I think it was..and it liked that. If you are using conventional oil... emmm well I would go back to a synthetic oil. The rotella t6 is a synthetic 5w40 weight.
    who knows
    in my bike, I use Honda only oil. from what I understand they are specifically designed with metals in your engine taken into account.
    in my car I always use mobile1 which I assumed was synthetic
    Two of the Syntec blends are VAG whatever-whatever approved. I run it pretty much exclusively in my 2.0t TSI Jetta. I started doing it to maintain compliance with the warranty. I kept doing it out of dumb habit. I get it for reasonable money at Autozone. They do a deal very frequently.
    Oh fuck.. I just posted in an oil thread.
    OMG YES IT TURNED INTO AN OIL THREAD!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Autozone oil deal-imageuploadedbytapatalk1397469720-154369-jpg
    I'm hoping they start making motor oil in addition to their gun oil. Not synthetic but I'd use the shit out of it.
    Mobil one synthetic meets HTO-06 specifications. Along with amsoil and pennzoil platinum. Good enough for me to say it's good enough.
    Lifer FirstDuc-1098's Avatar
    Central Mass
    bought Castrol PowerRS and got a rebate form for a Castrol hat
    Shit Corey says:
  1. Shell Rotella T6 on sale - AutoZone
    By scootertrash in forum General Bike Related
    Last Post: 06-12-13, 12:23 PM
  2. deal on a 08 klr?
    By mikeb in forum General Bike Related
    Last Post: 01-30-08, 06:40 PM
  3. 8' ratcheting motorcycle tiedowns $3.98 @ autozone
    Last Post: 03-08-07, 12:56 AM
