Results 1 to 15 of 15
SV650 Clutch issue
    Mar 2021
    RI
    SV650 Clutch issue
    Having a very strange issue with my clutch and was referred here as many of you owned/worked on/or raced on the SV platform. When pulling in the clutch lever, the bike still feels to be in hanging in gear; it is very difficult to push the bike around the garage while it is "in gear". The bike moves as expected when neutral is selected, but, all other gears it has the same symptom. Clutch cable is in good shape and adjusted properly, worm gear plunger has been disassembled, re-greased and adjusted (in good working order). Pin to the clutch case is clean and free of debris and moves as expected when pulling the clutch lever.
    So I took apart the clutch yesterday and found some black spots on a few of the steel discs, not blue at all, just black (see picture). All of the fiber plates seem to be in good shape, but, I am very new to this, and it is my first motorcycle clutch job, any info or thoughts on the issue would be greatly appreciated!
    thanks,
    jp
    Re: SV650 Clutch issue
    That looks like a hot spot...
    Are all the steels flat or are any of them warped?
    Got a micrometer? any of em have thickness variations?
    Bet the problem would prob go away with a new clutch pack.
    warping from clutching up wheelies, I agree with Oreo
    Lifer isaac_'s Avatar
    Jul 2014
    Central CT
    Doesn't it concern you the spot is only one place? Wouldn't you expect spots in a sinoid pattern? Could there be an issue with the springs (highly unlikely)?
    If you think clutching up wheelies on an SV warps steels then technically we agree to disagree.
    I'd wager that my race starts beat up a clutch a lot more than my clutching up wheelies.
    The bluing in one spot is why I'm wondering if it's warped, bent or out-of-spec steels, mostly because I can't think of any other reason off the top of my head that would cause that.
    Springs..... maybe?
    What does the clutch basket look like? Can't imagine that's the culprit but it's a question worth asking.
    You can use a piece of glass or a tile to check for flatness.
    Springs..... maybe?
    something is making the clutch pac drag, worn clutch would tend to slip instead, warping, what ever the cause, no, I don't really think wheelies caused it
    Mar 2021
    RI
    I checked them all with a micrometer and they were all within thickness spec. The plates appeared to be flat, checking them against something flat is a good idea...a little more calibrated than....my eyeball.
    All of the springs were between 1.99"-2.04" so I would assume that those are okay.
    Thanks for the info everyone, will keep updated if solved.
    Quote Originally Posted by jp View Post
    What about the clutch basket? If the "fingers" on the side have grooves or ridges, they will stop the steels & frictions moving in and out.
    That plate looks fine. My guess is the odd adjuster that bolts to the cases is out. It's a tricky bugger to set up sometimes. I had issues with it when I put a slipper clutch in.
    Aug 2011
    Coventry, RI
    Out of adjustment is my guess. Not at the lever. You need to adjust the clutch down at the push rod.
    Mar 2021
    RI
    Update time. number9 I think you were on to something. The basket and the carrier both are a bit grooved, see pictures. I'm guessing its time to replace these? Or is this normal wear? I put the whole thing back together with new plates, fibers, and spacer washers (before realizing that the grooves were indeed there) and had the same symptoms...took it back apart, and well here we are. Any thoughts by people smarter than I am on this subject?
    SV650 Clutch issue-h8ecowm-jpg
    SV650 Clutch issue-qjlt36m-jpg
    That's normal and not the cause of the issue. It is most certainly out of adjustment at the plunger.
    Mar 2021
    RI
    Bike is all fixed and running. Thanks for the help everyone. The clutch release mechanism was the issue, it was missing bearings inside that I initially didn't notice. Bought a new one, bolted it on, and the problem disappeared magically. Appreciate all of the ideas and input.
    Awesome. Glad you got it sorted!
  1. Wanted - Parts & Tools | Sv650 slipper clutch - gen 2
    By cbrace in forum Wanted
    Last Post: 07-02-19, 08:57 AM
  2. Wanted - Parts & Tools | Clutch perch bolt for 03+ SV650 (or complete perch) also 00-03 GSXR clutch perch
    By juha_teuvonnen in forum Wanted
    Last Post: 05-22-18, 10:57 AM
  3. Best SV650 Clutch
    By Duffy21690 in forum Bike Maintenance
    Last Post: 03-19-15, 09:08 AM
  4. MT250 Clutch Issue:
    By AimlessMoto in forum Bike Maintenance
    Last Post: 03-21-11, 07:36 AM
