Results 1 to 15 of 15
Clutch basket wear - how much is too much?
    I've been having problems with my Rekluse EXP 3.0 Z-StartPro. I called Rekluse and they've been very helpful so far, and they recommended opening the clutch up and taking a look.
    Per their documentation, they say that basket wear is a problem. But how much is too much? This is what I see on the edges of what I assume is the OEM basket:
    Clutch basket wear - how much is too much?-image1-jpg
    Am I worried about nothing? The options for a replacement basket seem to include OEM KTM, Hinson, Pro-X, Wiseco, Barnett, Moose and Rekluse.
    Re: Clutch basket wear - how much is too much?
    Yup, that's enough wear to cause engagement problems. Basically, if you can feel the depressions like that... One cheapskate trick is to file them flat to squeeze some more miles out of it.
    I've seen threads about guys filing them down on ktmtalk, but for $150-200 I'd just replace it. Are any of those billet baskets better than the others? Pro-X seem to be the cheapest, and Rekluse the most expensive.
    Edit: I don't even need to use my fingernail to catch the wear on the basket, I can feel it with my fingertip. All the friction plates measure within spec (2.7mm thick) and the steels look fine. I'll get some glass tomorrow to make sure everything is flat.
    If I put everything back together and ride it like it is for a day (with fresh oil!), can I do any real damage?
    Haverhill, MA
    Not likely more so just have to deal with the annoying lack of the clutch disengaging when you want it to or possibly slipping when you don't want it to. Don't get me wrong, if it is slipping due to the worn basket and you keep hammering it to get moving you will wear out your clutch plates steels more than normal but if you're just going out for an afternoon fun ride and not riding at Southwick or anything like that you should be fine.
    I've got half a day off on Thursday so I'd love to go back to Crow Hill. But, I'm slow, and pretty easy on the clutch...
    File it, put it back together, ride it until the new basket comes in and you get a chance to pull it apart again.
    In my experience the fancy ones still wear. Hard anodizing doesn't really make aluminum hard enough to resist steel. That said, the might last a little longer than stock. I would simply price shop for a recreational use bike.
    Is it Hinson that makes one with steel inserts at the wear points?
    Member TripleTaco's Avatar
    Aug 2009
    Southern NH
    I know Barnett makes one, maybe Hinson does too. Never tried one but seems like that'd be a pretty slick solution for $250.
    Off-Road Clutch Baskets
    FWIW, Ive had good luck carefully filing the grooves out on two bikes in the past. I had a YZ that was SUPER grabby. That worked out fine for the short time I owned it. Then I did the same on my current KTM 200. It wasnt as bad to start with, but its held up great now over 130hrs of my abuse. Although Ive noticed it might be getting a little grabby lately, but not enough to force me to dig into anything yet.
    '96 DR350SE
    '00 KTM 200exc
    '07 Speed Triple - sold
    '98 YZ125 - sold
    Yeah, I think at the end of the season I'll get an MX bike as well. I started taking suggestions in the big dirty thread..
    I should take the basket out to file it down, right? Or can I get away with using grease and maybe a shop towel to catch the shavings...
    Aww fuck it, I'll take it out.
    I think so yeah, and they're replaceable.
    Central MA
    I would file it, and see what effect it has on the Rekluse's operation. I know that Rekluse clutches can be finicky. On my KTM 4-stroke, they recommend replacing the rubber clutch dampers every 20 hours, or something like that.
    I got a small pane of glass from a local window company and started checking. Every friction plate was straight. Every steel plate was straight.. except the last one. It's warped enough that you can slide another steel underneath one corner of it.
    Swap it to the outside, one position in if you want to ride for a day.
    Or maybe just wait til you have a few new steels to ride.
    Rekluse said, "You can't do any more damage by riding it as it is". I was going to ride yesterday but ended up having too much shit to do
    I ordered new steels ($50), new frictions ($112), new wave springs (3 @ $5) and a new gasket ($20!). I'll probably file down the basket before I order a new one next week or the week after. They suspect the installed gap was too big, leading to too much heat and ultimately a warped steel. The crummy basket wouldn't have helped. The new steels pack comes with an alignment steel, which is thinner than the rest of the steels, so I should be able to get everything in spec.
  1. I've got a CB450 basket case.
    By hot karl in forum For Sale
    Last Post: 07-14-12, 01:27 AM
  2. Basket ball setup.
    By Rosco61 in forum For Sale
    Last Post: 11-05-11, 05:07 PM
  3. wanted CRF 450 Head/Clutch Basket
    By lrrs428 in forum For Sale
    Last Post: 10-10-09, 01:29 AM
