Results 1 to 7 of 7
Valve Clearance Adjustment
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    Anybody on here do this. To be honest I am looking for someone to sit with me and walk me through it. I've never adjusted valves, and while I do have basic mechanical knowledge and a manual I would feel A LOT better if someone who actually knew what they were doing was around. Not an immediate need - looks like i'll need some specialty tools (micrometer, and shims) before I start pulling stuff apart, but before spring I'd like to spend a day and get this done - I'm at about 18k mile on the RC51 so it's definitely time.
    Raymond NH
    Re: Valve Clearance Adjustment
    I've never done them on an RC51, so I have nothing bike specific to offer, but if you simply follow the manual, it should not be terribly hard. They need 9.48 mm shims, IIRC. I recommend getting a Hot Cams kit for around $75. The only other tool you need is a set of feeler gauges. No need for a micrometer, the shims are marked with their thickness.
    Derry NH
    If anything's off, you may need to get the correct spec shims from a dealer, so it may not be an easy one day job. Not hard though. I know on my R6, it gives you a table in the repair manual in order to find the needed shims. You would go in and measure all the clearances, take down numbers to figure out the shims needed, and get any you don't have from the dealer.
    Dec 2005
    Near The Dragon
    Quote Originally Posted by Eric Baker View Post
    as has been said repeatedly.. this is apparently not a shim style valvetrain
    Get out while you can
    Find your own path
    Quote Originally Posted by Cerberus View Post
    I think this one is. My thread was not shim type but the RC is.
    Dec 2005
    Near The Dragon
    Oops my bad. A lack of reading comprehension, ironically enough
    Find your own path
    Jul 2008
    Massachusetts
    We'll find out soon enough. I pulled the front end off this morning - forks are going in for new seals. Sounds like it will be a two day affair - one to pull it apart and measure, and a second to switch out any shims once the thickness has been determined. Bergs has volunteered oversight on the valve adjustment - very cool of him. I've got a bit of work to pull the gas tank and get everything ready, but that should be straight forward enough. I am looking forward to learning this for future use.
  1. Valve Clearance the fast way
    By Jim in forum Bike Maintenance
    Last Post: 05-23-13, 10:40 AM
  2. check valve clearance on 01 gsxr 600?
    By burtonboarder23 in forum Bike Maintenance
    Last Post: 02-26-13, 10:33 PM
  3. Business | Valve adjustment
    By netputty in forum Business & Product Reviews
    Last Post: 10-24-12, 11:46 AM
  4. valve adjustment
    By nilez in forum Bike Maintenance
    Last Post: 04-15-08, 07:16 PM
  5. Valve clearance check- where?
    By nerijusj in forum Bike Maintenance
    Last Post: 03-13-08, 08:26 AM
