Results 1 to 6 of 6
Fork cartridge, emulators, and pistons?
    Senior Member kumpy's Avatar
    May 2012
    Norton MA
    What are the differences in performance and pricing between getting emulators, cartridges, and pistons? I know i got Ohlins cartridges which I believe is the entire internals of the fork other than the outter sleeve and lower shaft (inverted forks). As for pistons, I know they're about 1/2 the price of cartridges, but what are the performance benefits of going to cartridges? Also, what are emulators? Does it depend on your bike, where some bikes uses emulators and some use pistons and some use cartridges only? Please no irrelevant comments like, just factual comments that will help clarify my confusion.
    Re: Fork cartridge, emulators, and pistons?
    Emulators are for damper type forks. They try to emulate cartridges.
    ...inside the van. loudog's Avatar
    Central, MA
    Cartridges > Pistons alone > Emulators (for damper rods suspension like Smutty said).
    No need to change what you got.
    Retired LRRS/CCS EX #212 | Woodcraft | Armour Bodies | Dainese USA |
    Lifer SwiftTone's Avatar
    Norwood, MA
    Quote Originally Posted by loudog View Post
    So where does valving fit in the picture?
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    A Cartridge generally refers to an entire "drop in" kit.
    Pull out the whole assembly (minus springs) and drop in the new one.
    Valving is a component of the larger "cartridge". There's a lot of black magic associated with selecting the proper valving, shims, and assundry other bits that make up the "cartridge" that are still something of a mystery to me.
    Jan 2010
    Farmington, CT
    Here is a good thread on Fork Questions (specifically related to 2000+ 5KE TZ250), but the pictures give a good explanation on how the shims are configured to provide valving for compression & rebound in a set of cartridge forks.
    http://www.tz250.com/cgi-bin/forums/...ST&f=15&t=8552
  1. For free: Cartridge Oil Filter KN-152
    By keeena in forum One Man's Garbage...
    Last Post: 05-21-19, 01:14 PM
  2. sv650 forks w/springs and emulators
    By darkduc7 in forum For Sale
    Last Post: 06-16-13, 08:45 PM
  3. Marzocchi cartridge cap not reaching specified torque
    By kbroderick in forum Bike Maintenance
    Last Post: 07-03-12, 04:26 PM
  4. Replies: 7
    Last Post: 07-08-11, 11:07 AM
  5. Cartridge fork revalve
    By Paul_E_D in forum Bike Maintenance
    Last Post: 04-03-04, 10:15 AM
