Results 1 to 10 of 10
95 GPZ 1100 starting/stalling issue
    Apr 2011
    I'm having a problem that has started over the last 2 weeks.
    first off i'm driving around 40-45 mph and the bike suddenly starts to buck like i'm out of fuel. i check the gauge as it dies, and i've got half a tank.
    i pull over and try to restart, it cranks but wont turn over. then i put in the choke and it fires up.
    drive 40 feet, same thing. this time the choke doesnt make it turn over. i turn the key to off, then on and it fires up.
    i drive to the gas stattion and top it off, and it runs fine and i get home.
    few days past and it starts and run perfect. then suddenly i come out of work and try to start it and it wont start, i turn the key off then on, and it starts.
    anyone have any ideas? battery? starter? something else?
    Chris
    Westford, MA
    Re: 95 GPZ 1100 starting/stalling issue
    Check your vacuum lines. I'm guessing it has CV carbs?
    ...I have your pants!!!
    Lifer TIMMYDUCK's Avatar
    Feb 2003
    The 14th State Vermont
    Also check out the fuel filter located on the petcock inside the fuel tank.
    TIMMYDUCK
    Apr 2011
    I'm not really sure about the CV carbs or how to check the vacuum lines. i'll look at the maintenance book i have for it.
    I checked the fuel filter reservoir, should that be nearly full?
    Walpole
    Change your fuel line. The original fuel line may be collapsing on the inside. This fucking ethanol fuel likes to attack anything rubber.
    2018 Harley Road Glide
    2000 Ducati 900ss
    2003 Harley Softail Deuce
    Feb 2003
    IN my humble opinion it is rust flakes/ sludge build up on the tower of your petcock after 16 years of use.
    Part number 92022 in this schematic. Don't ask me how I know.
    http://www.bikebandit.com/houseofmot...m3424#sch64376
    TIMMYDUCK
    Apr 2011
    The petcock doesnt even work anymore... its probably all clogged up.
    Old School Fool. ZX11D's Avatar
    Jan 2009
    Wilmington MA
    Will it stay running if you leave the choke on? Sounds like what my zx1100 was doing. Took it to the dealer and got soaked a bunch for a thorough carb cleaning according to the mechanic.
    Apr 2011
    it stays running with the choke on.
    the thing its really more is cranking and not turning over, then i will turn the key off and on, and it will turn right over.
    seems like it is doing it every 3-4 starts now. could it be the battery?
    Apr 2011
    I'm gonna order a full petcock from ebay. and give that a try
  1. Gen 1 SV Starting/idle issue
    By GingahNinjah in forum Bike Maintenance
    Last Post: 09-11-13, 09:23 PM
  2. 01 GSXR 750 stalling issue
    By loki32687 in forum Bike Maintenance
    Last Post: 07-15-13, 09:28 AM
  3. Stalling Issue
    By Drewski in forum General Bike Related
    Last Post: 06-26-13, 02:47 PM
  4. gsxr600/750 starting issue, FI?
    By bigred875 in forum Bike Maintenance
    Last Post: 09-22-07, 11:40 PM
  5. Issue with bike starting
    By Billy in forum General Bike Related
    Last Post: 03-07-06, 07:29 PM
