Results 1 to 10 of 10
95 ZX6R Fuel issue ?
    Bike Junky
    Oct 2009
    Conway NH
    Question 95 ZX6R Fuel issue ?
    Ok this is my issue. The bike starts fine though the choke doesnt really seem to do much and runs great on the bottom all through first gear now once I hit second and up once she gets to 4.5K thru 7K the throttle is pretty much non existent then she bucks as it gets close to 7 then cleans out and goes like I think it should. Now question is any ideas and what would the syptoms be of a choke thats stuck on cause the bike seems to use a lot of gas. The way it runs kinda of makes me think of something with the choke on but again not sure. Any help is appreciated because it makes it really hard to work on my cornering when I get no throttle response right in the heart of the 45-60 mph range.
    Ride On,
    Todd W.
    Re: 95 ZX6R Fuel issue ?
    low compression in one of the cylinders / clean carbs + spark plugs..
    good be messed up fuel line too.. had similar problems with an older katana
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Get the carbs cleaned and synched then report back.
    Posted by Jane in BoxChat
    Junior Member NRrice's Avatar
    Mar 2011
    Lowell MA
    Yes!! carb clean is a must.
    ZX6-R
    Bike Junky
    Oct 2009
    Conway NH
    Already cleaned the dang things twice guess third times a charm hopefully lol
    Ride On,
    Todd W.
    Mar 2011
    Lowell MA
    yeah you may have some dirt going through your filter. when I drop off the relay for you couple of months ago, inside of your tank looked kinda dirty. I would recommend clean out the thank again too. And you may have to take it easy on the corner for now.
    ZX6-R
    Lifer NobodySpecific's Avatar
    Apr 2008
    Burlington, VT
    Quote Originally Posted by nhtodd View Post
    Did you clean them well though? I can wash my car by just getting it wet and doing a half-assed sponge job (that sounds dirty), but that doesn't mean the car is actually clean. Same goes for carbs. You have to ensure that they really are clean when you are done.
    '06 Triumph Sprint ST ABS
    '90 Yamaha XT350
    Bike Junky
    Oct 2009
    Conway NH
    Well I thought I cleaned them good at least the jets and bowls. I'll strip them completely down and clean everything peice by peice hopefully that'll do it. I did clean the tank after you seen it Nic but I'll do that again too.
    Ride On,
    Todd W.
    Westford, Ma
    make sure you run a wire through the jets to make SURE they are clean. compressed air doesn't work. Then get them synched
    Ray Viernes, Scammer! Ray-Ray's Avatar
    Oct 2009
    But also make sure nor to scar the jets
  1. Help with carb/fuel issue needed, '81 KZ550
    By SprintPoser in forum Bike Maintenance
    Last Post: 06-16-17, 04:22 PM
  2. 2003 Honda shadow spirit 750 fuel or carbs issue ?
    By Nguyen.gixxer in forum Bike Maintenance
    Last Post: 06-13-12, 03:15 PM
  3. ZX10r / ZX6r Fuel Pumps Interchangable
    By VinceF2 in forum Bike Maintenance
    Last Post: 07-14-11, 03:10 PM
  4. EX250 Fuel Issue
    By TimmyB in forum Bike Maintenance
    Last Post: 10-09-09, 09:59 AM
  5. ONLINE SERVICE MANUAL!!! 00-02 zx6r, 03-04 zx6r(rr?)
    Last Post: 06-20-04, 11:01 AM
