Page 1 of 3 123 LastLast
Results 1 to 25 of 56
97 gsxr rear wheel dosen't spin in neutral
    Jul 2006
    ipswich,ma
    Tried to move my srad around in the garage but rear wheel doesn't want to spin.I put it on the stand and tried turning buy hand in neutral.It does turn but not easy.The rear brake is NOT hung up.
    This happened to me my last race weekend.The bike rolled off the truck but it felt like something was hanging up.The rear rotor was a little rusty so I thought it was the brake.I put it on the stand,clicked 1st and let it spin a bit,rode it around the pits a little then did 3 races that day.It rolled on and off the truck fine.Forgot all about 'till it did again.
    Any ideas??
    LRRS #649 NV
    Lifer DuncanMoto's Avatar
    Re: 97 gsxr rear wheel dosen't spin in neutral
    tell us if it is brake drag or engine drag.
    I'm betting a sticking rear caliper in need of a honning and rebuild.
    Jul 2006
    ipswich,ma
    It's not the rear brake.I can see the chain tighten when I try to turn the wheel.
    LRRS #649 NV
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Quote Originally Posted by DuncanMoto View Post
    I'll bet the rear caliper too.
    Posted by Jane in BoxChat
    Jul 2006
    ipswich,ma
    The rear brake is NOT hanging up.
    LRRS #649 NV
    Dec 2003
    Ma
    Is it the rear brake hanging up?
    Get a soft face mallet, and give the caliper a couple smart whacks on the side, like you were trying to drive a nail through the body, through the face of the piston, through the pad, rotor, pad, piston, opposite side body, in one swing.
    Just Registered drop's Avatar
    Bradford, MA
    Quote Originally Posted by slamdik View Post
    the chain will always tighten up when you spin the rear wheel. this is not necessarily indicative of a problem.
    - Jamie
    2009 K 1300 S
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    is your wheel way out of alignment? maybe the bike is stuck in gear?
    Meriden, Ct
    Wheel bearings?
    Jul 2006
    ipswich,ma
    It does feel like it's stuck in gear but it's in neutral.The chain tightens up(very tight) in both directions.
    LRRS #649 NV
    Jul 2006
    ipswich,ma
    Maybe I should check the rear brake.
    LRRS #649 NV
    how about putting the bike on a rear stand and taking off the rear caliper. just to prove if it's the rear brake or not
    if you take the rear wheel off does it spin then?
    All strippers SHOULD have fake tits!
    Quote Originally Posted by 1/2pint View Post
    Jul 2006
    ipswich,ma
    Quote Originally Posted by DBKromz View Post
    The rear pads are loose.I can move them around easily.
    The wheel moves back and forth(the chain slack).
    LRRS #649 NV
    will the wheel spin if you grab the clutch?
    Jul 2008
    Marlborough Mass
    so you sure its not the rear brake
    Jul 2006
    ipswich,ma
    Nope.
    LRRS #649 NV
    Jul 2006
    ipswich,ma
    I took the wheel off and it DOES roll on the ground so it's not the wheel or tire.
    LRRS #649 NV
    Lifer TIMMYDUCK's Avatar
    Feb 2003
    The 14th State Vermont
    Since it is not your rear brakes , check your wheel bearings and and maybe put some axle grease on your axle shaft.
    TIMMYDUCK
    Jul 2006
    ipswich,ma
    I had the wheel off recently and the bearings seemed ok.The chain is stopping it from turning(front sprocket).
    LRRS #649 NV
    Dec 2003
    Ma
    countershaft bearing?
    Dec 2003
    Ma
    What you need to do, is just get a few guys to lift it up.
  1. For Sale - Parts & Tools | 05 GSXR 600 / 750 Rear Wheel
    By RacerXnh10 in forum For Sale
    Last Post: 04-11-14, 08:46 PM
  2. For Sale - Parts & Tools | 96-99 GSXR 600 / 750 Rear Wheel
    Last Post: 04-11-14, 08:45 PM
  3. GSXR Rear Wheel with Rotor
    By Dayon in forum For Sale
    Last Post: 03-16-11, 09:33 PM
  4. 04-05 GSXR rear wheel
    By Speed Demon 828 in forum For Sale
    Last Post: 12-30-10, 09:55 AM
  5. 04 gsxr 600/750 rear wheel
    By FAST GSXR750 in forum For Sale
    Last Post: 06-27-10, 11:07 AM
