Tried to move my srad around in the garage but rear wheel doesn't want to spin.I put it on the stand and tried turning buy hand in neutral.It does turn but not easy.The rear brake is NOT hung up.
This happened to me my last race weekend.The bike rolled off the truck but it felt like something was hanging up.The rear rotor was a little rusty so I thought it was the brake.I put it on the stand,clicked 1st and let it spin a bit,rode it around the pits a little then did 3 races that day.It rolled on and off the truck fine.Forgot all about 'till it did again.
Any ideas??
LRRS #649 NV
tell us if it is brake drag or engine drag.
I'm betting a sticking rear caliper in need of a honning and rebuild.
It's not the rear brake.I can see the chain tighten when I try to turn the wheel.
LRRS #649 NV
The rear brake is NOT hanging up.
LRRS #649 NV
Is it the rear brake hanging up?
Get a soft face mallet, and give the caliper a couple smart whacks on the side, like you were trying to drive a nail through the body, through the face of the piston, through the pad, rotor, pad, piston, opposite side body, in one swing.
is your wheel way out of alignment? maybe the bike is stuck in gear?
It does feel like it's stuck in gear but it's in neutral.The chain tightens up(very tight) in both directions.
LRRS #649 NV
Maybe I should check the rear brake.![]()
LRRS #649 NV
if you take the rear wheel off does it spin then?
All strippers SHOULD have fake tits!
I took the wheel off and it DOES roll on the ground so it's not the wheel or tire.
LRRS #649 NV
Since it is not your rear brakes , check your wheel bearings and and maybe put some axle grease on your axle shaft.
TIMMYDUCK
countershaft bearing?
What you need to do, is just get a few guys to lift it up.
