Results 1 to 7 of 7
Tire Balancing
    KB KB's Avatar
    Manchester NH
    Tire Balancing
    I mounted some tires for skiierx this past week. We got the beads broke (I made a bead breaker) no problem and the tire mounted.
    However the balancing part kinda threw me for a loop. I have read up on it here and other sites. I found the heavy spot of the wheel. Marked it and then mounted the tire with the light spot marking to the heavy spot of the wheel.
    Now I put the wheel on 2 jackstands wiht a 1 inch piece of electrical conduit as my axle. Spun it and the heavy spot found the bottom. I started adding weights in 1/4 oz increments 180 from the heavt spot. Spun the wheel and hoped that it would sart to find random spots to stop. Well after about 1 and a 3/4 oz of weight it still found the same spot each time. So we broke the bead and then mounted the light marking on the tire to the valve stem.
    Started over. Heavy spot was 180 from the valve stem. So I added weights to the valve stem till she stopped at random spots. This time it only required about 1/2 oz of weight and the rim stopped at random spots.
    Is this process this whacky or is it me being whacky.
    Can anyone that uses this method shed some light? Shold the weights be near the valve stem?
    Skiierx has not complained that the tires are out of balance but it just seemed like it was a whacky way to do it.
    Also I'm in Woburn and if anyone needs tires moutned I'll do them for short short money or beer.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Jul 2002
    Waltham
    Tire Balancing
    The tires seemed great and no vibrations at all!
    Thanks
    Jamie
    Lifer legalspeed's Avatar
    Somersworth, NH
    Tire Balancing
    You're just being more exact. Most keep adding weights.
    You can do my streets any day.
    LRRS\CCS\WERA #486
    Somersworth, NH
    Tire Balancing
    skiierx, there is still a pillion seat with your name on it!
    LRRS\CCS\WERA #486
    Tire Balancing
    If I remember, the weights I use are in 1/4 ounce increments. Doesn't sound whacky 'tal. I've hadta use more than 3/4 oz on tires before...
    My rain tires required like, three pounds of weights! (...okay, not three pounds, but A LOT...)
    If it works, it works. Run with 'em...
    Jul 2002
    Waltham
    Tire Balancing
    Thanks, but got rid of that girl!
    Jamie
    KB KB's Avatar
    Manchester NH
    Tire Balancing
    Yeah I am being to exact. Bad habit I guess. ADD is a terrible thing!!!
    11 days tillt he gap. Jamie are my tires in yet? I need to get them moutned and test the limits before the gap!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
  1. tire mounting and balancing near franklin
    By gamorg02 in forum General Bike Related
    Last Post: 10-03-10, 07:22 PM
  2. tire mounting/balancing
    By darkduc7 in forum Vermont Events
    Last Post: 06-21-10, 09:15 PM
  3. Tire mounting and balancing - southern NH
    By Fitz in forum Pit Area
    Last Post: 07-09-08, 07:08 PM
  4. WHO?: Tire Mounting and Balancing
    By Suf Daddy in forum General Bike Related
    Last Post: 07-16-06, 09:31 AM
  5. Tire balancing...
    By Tricky Mike in forum Bike Maintenance
    Last Post: 06-12-06, 01:03 PM
