Results 1 to 8 of 8
49 cc four stroke trouble
    Lifer akira700's Avatar
    Apr 2005
    in the city
    help
    So my scooter is misbehaving. Its a four stroke.
    It intermittently bogs when applying throttle from
    a stop. Its like I twist but the engine doesnt react.
    Then after about 3 seconds it decides to accelerate.
    Its like there are 1-2 dead spots between 0% and 100% throttle.
    But not all the time.
    Does this mean the carburator jets are clogged?
    A hose loose or cracked? Seems to have appeared after I adjusted the
    idle speed up from 1000 to about 2000 rpm. related?
    2008 Honda CBR 600RR
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Re: 49 cc four stroke trouble
    Quote Originally Posted by akira700 View Post
    help
    If you raised your idle to compensate for a problem, check your pilot jet (might as well do them all) - clean them with air, then safety wire.
    Also check for leaks (squirt a soapy solution around the air boots)
    Apr 2005
    in the city
    Thanks Kitt.
    Its Frikken Denno's fault for selling me a cheap chinese POS!
    Just kidding dude!
    Its actually quite a good deal for $500!
    It saves me $5 in parking every day and maybe a $1 of
    gas. I fill it up weekly and it only takes like $1-$2 of gas to
    filler up!
    Just need to get this carb issue fixed up.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    It does sound like a jet issue. I agree clean them with wire, air and a shot of carb cleaner.
    Posted by Jane in BoxChat
    Screw it, lets go riding. CrotchRocketeer's Avatar
    Westfield, MA
    i like to check for air leaks with either something like carb cleaner or starting fluid. if you RPM raises, then you know its sucking that stuff through. sometimes i'll use WD40. that'll make your RPMS drop because they switched the propellent to CO2. ( i believe?)
    Apr 2005
    in the city
    Quote Originally Posted by CrotchRocketeer View Post
    Where would these air leaks be? Between the air filter and the carb?
    No Post Count Lurker RGVER's Avatar
    Nov 2006
    Milford, MA
    help
    my scooter
    Well theres your problem
    See my sig
    Westfield, MA
    it could be the in boot between the air filter and the carb, but that would cause a mild lean condition. probably not enough to show the problems your getting.
    if it is an air leak, its probably between the carb and the engine intake. the engines vaccum would suck "false air", that hasnt passed through the carb to take up gas along with it. it can cause all sorts of sputtering and stalling, but is less evident at high RPM.
    good luck!
  1. 2 Stroke in modern 4 stroke chassis
    By REXXX in forum General Bike Related
    Last Post: 12-09-10, 01:23 PM
  2. No End of Trouble
    By Paul_E_D in forum Pit Area
    Last Post: 08-07-05, 08:41 PM
  3. Here comes TROUBLE....
    By GadgettR1 in forum General Bike Related
    Last Post: 11-16-01, 12:28 PM
