What should I be doing for maintenance to my 01 R6 with 15K miles? So far I have just been doing tires and oil changed, oh and recently a battery and coupler for the rectifier. So suggestions would be good, any thoughts?
Thanks,
Kevin
'05 Warrior
Quincy, MA
AIM: BostonianR6
Hi Kevin how's it goin - remember me?![]()
Brake fluid, check brake pads, valve adjustments, air filter, regrease axles and pivots, check wheel and steering head bearings.Originally posted by kmobrien76
Thanks,
derek
Derek, think it would be alright to have that maintenance done at the end of the season?
Elaine, ofcourse I remember you, drop me an e-mail, I sent you a PM...kmobrien76@yahoo.com is my current e-mail...
Kevin
'05 Warrior
Quincy, MA
AIM: BostonianR6
Sure, if everything seems to be ok.
As a weekly thing, all riders should check:
1. Tire pressures
2. Chain adjustment/lube
3. Oil level
4. Water level
5. Brake pads (visual check to see if they are worn)
Sounds right...yeah I learned that tire pressure can/will decrease and to check that more often...last week my front was down to 10psi...aahhhh...
Everything feels fine, I'll have the 15-20K maintenance done at the end of the season and keep up on the rest...
Kevin
'05 Warrior
Quincy, MA
AIM: BostonianR6
