Results 1 to 7 of 7
Looks like dead battery...but its not...
    Junior Member Romeo's Avatar
    Woburn
    my bike is broken, and i don't know whats going on. if anyone can help me, thatd be great.
    When i turn the key, nothing happens. the electronics dont turn on, the engine doesn't crank, the starter doesn't even click. Dead battery? nope...the battery is fine. i checked the fuses...fine too.
    Then my friends pushed me and we got the bike started and running. It ran and idled choppy and didnt rev past 4k...but the kicker is that for the 15 min that it was running, the electronics didnt work. Every couple minutes the rpm gauge goes all the way up then down, and some lights on the dash flash...but most of the time its completely off.
    Does anyone know what the problem could be? i'm all out of ideas....
    please help
    thanks guys
    Feb 2010
    Southbridge
    Re: Looks like dead battery...but its not...
    bad ground.. battery has to have ground to work. so just by checking the battery wont work. use a multi meter and check for continuity with the battery terminals to the chassis and to the fuse / distributor block.
    Degsy: "i never had red hair"
    Old School Fool. ZX11D's Avatar
    Jan 2009
    Wilmington MA
    Good advice. A buddy of mine had the same trhing happen. Had to have the bike picked up and brought in to the shop not to mention the nice "diagnostic fee" for a" bad ground" they told him he had.
    Feb 2010
    Southbridge
    i would be happy to look at it for you. my shop rate is $65 per hr. i have extensive electronics experience and could most likely figure it out in a jiffy. feel free to check out my reviews on here. i can even pick up the bike for you (fee dependent on location if in fact there even is one.) give me a call and we can figure out your best route of action if i cant figure it out over the phone.
    my cell is 774-200-6395
    Lifer ilikenapalm's Avatar
    Connecticut
    Before you do anything.. Make sure your battery cables are tight.
    Mar 2011
    Make sure your battery connections are tight and not filled with corrosion. Use a wire brush if needed to scrape away the metal contacts. Make sure it is tight.
    If not...check your wires, make sure they are not frayed/ cut: because nothing is working, this will most likely be near the battery.
    Senior Member JalopySiR's Avatar
    Dec 2008
    Charleston, SC
    Definately check all the ground connections.
    I also know that on 5th Gen VFRs the R/R will go bad and cause wacky electronics issues that seem like a dead battery.
    I'm assuming your bike is a GSX-R, from your avatar.
    2002 RVT1000R
    1998 VFR800Fi
    2002 CR80RB
  1. Dead Battery or ???
    By Marc R in forum General Bike Related
    Last Post: 06-16-15, 05:06 AM
  2. Dead battery troubleshooting.
    By backinthesaddle in forum Bike Maintenance
    Last Post: 09-03-12, 10:16 AM
  3. Dead Battery?
    By Mike02048 in forum General Bike Related
    Last Post: 03-20-11, 08:57 PM
  4. Dead battery
    Last Post: 03-07-11, 08:21 PM
  5. dead friggin' battery
    By Awesome in forum Bike Maintenance
    Last Post: 10-31-04, 09:26 PM
