Results 1 to 25 of 43
Chain Adjuster Marks...
    Lifer greenmonster's Avatar
    Aug 2003
    Anyone use these factory markings to adjust their chain? Conventional wisdom on these is that they're a joke...don't use them!!!
    There's the string method...the rod method...the eyeball method....the laser method, and the time honored Hail Mary method.
    But really, has anyone actually used them with success? Can it be done?
    Your thoughts, please...
    Oh, I forgot to add, I charge double for Kawasaki's
    "My God, you're gonna have to cool me down, give me an ice block to shove in my pants or something".
    -Barbecue Lou
    Apr 2006
    Beverly, MA
    Re: Chain Adjuster Marks...
    The guys on the Versys forums mostly use the marks and said they've been fine. I think it's worth measuring if you can, but I wouldn't lose much sleep over using the marks alone.
    Lifer DuncanMoto's Avatar
    It really depends on the bike.
    I use a laser at the shop. Once a bike checks out that the marks are good you can use them.
    If anyone wants to come borrow the laser, drop on by. It takes 2 minutes to check.
    Beantown Stan's Avatar
    Needham, MA
    I use them and its fine
    Mike (Stan) Facebook username = MJStanley508
    2006 Suzuki GSXR 600
    Yoshi R-55 Slip-on, PUIG rear hugger, PUIG windscreen, Pazzo levers, 6k HID kit
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Never had a problem
    If they are removable etc maybe don't switch them
    I have axle nut snug
    use the screws to drive the assembly to the marks
    tighten the axle
    tighten the adjuster lock nuts
    Glen Beck is John the Baptist
    Needham, MA
    Sep 2007
    Middlebury VT
    Had 4 different bikes from 4 different manufactures.
    Have used factory marks.
    No issues yet.
    Aug 2003
    It's all good, then. Thanks!
    -Barbecue Lou
    never used them, never found them accurate. i use the wheel alignment tool for accurate measurements.
    Lifer DaveZX6r's Avatar
    NoChelmsford, Ma.
    I had two swing arms on my fzr. First one that came with the bike had a dent in the side and was slightly tweaked. Marks didn't work on that one. Second one straight, marks were close still had to sight down the chain. My zx6r I have now has no visible damage to swingarm, but the marks are about half off when i alighn my wheel. You can use the marks to get you close, but I'd recomend you allways at the least sight down the chain and don't get freaked if the marks don't line up to make the chain straight. When i picked up my zx6 it was aligned to the marks and when i pulled the wheel to get a new tire the sprocket had alot of side wear from the chain.
    talk to Jimmy Chance on WERA. Here's the thread for the alignment tool.
    basically put these through the rear axle & swingarm pivot, then measure.
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    Jim,
    I saw Degsy use those rods on my bike when I got new tires put on. Much easier then using the marks on the swingarm. Do I just email Jimmy and say I want a set of those rods?
    Quote Originally Posted by Billy View Post
    Jim,
    page 9 shows the newest pricing, which is $77 plus $10 shipping. he uses paypal, and i believe it's listed on page 1
    Feb 2006
    Metro West, MA
    nice, thanks for the tip.
    I Dance With Will
    Oct 2002
    unknown
    whats the laser look like or what's the method?
    Quote Originally Posted by DuncanMoto View Post
    "fuckit!"
    i heard a rumor that the Trickster may make some in the off season, but dont quote me on it. I havent bought these yet from WERA, since i'm hoping to support someone more local.
    Aug 2003
    Thanks for the link, Jim. Gonna be adjusting the chain, bleeding the brakes, etc., this coming weekend with Sean....I'll first try using the marks, and sight down the chain. This may sound crazy, but the idea came to mind that once you have it where you think it should be visually, how about measuring the distance between the outer edge of the sidewall (assuming you still have chicken strips, no matter how small they may be ) and the inside of the swing arm, at the same location point on both sides, and see if there is even the slightest difference in the gap? (using a ruler in 1/16's) Maybe then tweak a bit...before the final tighten down? Sound feasible or did I put too my crack in my coffee this morning?
    -Barbecue Lou
    for those who use the alignment tool, you're best buying a measuring tape that does millimeters. i'm picky, and wont be happy until each side is less than 1mm different. others would be happy with 3mm-4mm difference.
    Oct 2007
    Peabody Assachusetts
    I use a dial caliper.
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Quote Originally Posted by greenmonster View Post
    measuring the tire is probably less than ideal. you could probably measure at one point then spin the tire and measure again and get different measurements.
    I usually go by the marks and sight down the chain. not the most accurate way of course but haven't had a problem yet. If its too far off you should be able to feel it when you're riding.
    I Dance With Will
    Oct 2002
    unknown
    Quote Originally Posted by brendanp View Post
    do you find it hard due to different shape edge?
    "fuckit!"
    Oct 2007
    I dont understand your question Sir
    I Dance With Will
    Oct 2002
    unknown
    i dont know how to describe it.
    "fuckit!"
    Like this Profi Laser Cat
    Motion Pro CHAIN ALIGNMENT TOOL For $15-$20
    Have kept the chain and sprockets on my bike for 27,000+ miles.
  1. SV rear set adjuster plates.
    By obsolete in forum For Sale
    Last Post: 09-09-10, 01:03 PM
  2. Brembo MC w/ folding lever, remote adjuster
    By ridnwb in forum For Sale
    Last Post: 08-24-10, 11:17 AM
