Results 1 to 8 of 8
Quick connect for fuel line Gas tank work
    I would like to install a quick connect fuel line to my vintage race bike. I have seen a lot of plastic ones anyone have any feedback on these.
    Also, I need to slightly Modify the petcock opening on the gas tank to except a Pingel tap. Drained tank and letting it dry out. Using a Demel would be quick and easy or even a round file I don't need to remove much, should I coat the inside with water before I blow up!
    rides bikes
    Nov 2014
    Re: Quick connect for fuel line Gas tank work
    I used something very similar to this for years with no complaints. Did exactly what I needed and didn't leak fuel when disconnected.
    https://www.revzilla.com/motorcycle/...nnect-coupling
    Edit: looks like this specific one does not stop fuel from flowing when disconnected
    Dublin, NH
    I'd recommend checking out products from CPC. They make lots of disconnects, both plastic and metal. I assume you want a "dry break" one, which shuts off flow when disconnected?
    Something like this:
    https://slavensracing.com/shop/dry-b...r-performance/
    Or this:
    https://www.amazon.com/Motion-Pro-Qu...ustomerReviews
    2023 KTM 890 Adventure R
    I used the plastic ones on my FZR, no issues though they do restrict fuel flow a bit for a given line size, something to be aware of.
    5/16 line and dry break would be optimum. thanks for the input.
    Buy extra sets, that way you can have one end on a drain line for fast tank dumps.
    On the Pingel, be prepared to have to fuck with it to get it to flow reliably. On my GS I had to eventually pull the screens off or I'd starve my carbs for fuel, which is impressive considering it was a 40hp 500E that didn't exactly slurp gas at a high rate. I like the idea of Pingles, I'm not a big fan of the actual execution. Depending on the bike I've had better luck finding OEM units, typically from dirtbikes that can be crossed over to the existing OEM bolt/opening pattern.
    My issue with the tap is I added Keihin CR 29s, so no vacuum and gravity taps for my 77 KZ are very hard to find these days. I have run Pingels before and have had no issues
    I fit the Pingel to the tank, had to Dremel a little bit (fitting a round tap into a rectangle hole) Drained gas, used a fan to vent the fumes, put the tank in my slop sink filled with water and run water over where I was cutting. Still taking about it so it worked. Now drying tank.
