Results 1 to 15 of 15
bent valve
    bent valve
    compression test on my SV revealed 210psi rear/90 front, I've been quite a bit of oil the past 500 miles or so, about a half quart every tank off gas, but still only showing smoke on startup & hard acceleration/deceleration
    engines all torn apart now ( case is not split) the culprit being one of my front exaust valves not seating properly, quite a bit of play in the valve guide, lot of carbon around that exaust port.
    otherwise engine is very clean for 135k (210 in rear is as near to perfect as you can get)
    if measurements on rod deflection is ok, looks like a new top end only
    Jun 2005
    wow
    Thats one job that intimidates the shit out of me. So whats the story, what do u actually need to adjust/replace with that kinda mileage? Is it just a matter of replacing the culprit valve?
    bent valve
    Tim, cleaning & lubing your CHAIN intimidates you...
    Re: wow
    no, head has to be machined, new valve seat cut, and new valve guide pressed in
    I'll be gitting new pistons & rings too (oversize) prolly bump my cc's up from 645 to 652 (I think if I calculated right ) I "might" consider a 677cc or 700cc kit if the price diff isn't much
    MY bet is I damaged the valve a couple years ago when I downshifted into 1st @ 70mph,the valve is not noticably bent, it just doesn't seat right
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    Re: Re: wow
    Have him put stainless steel valves in there Randy, they're better and cost the same as standard.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    bent valve
    looks like I'm likley bringing the sV home in a box and tinker as I have time, in meantime buy a new V-Strom
    all the valve guides are shot, they don't come as a separate item to press in = new heads
    cylinders are worn beyond what an overbore can cure
    we can't figure out why the cam chains haven't broke yet = split case to replace the chains, might's well add an oil pump to the list
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    bent valve
    That's the bike for you Randy. The SV served you well.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Lifer Karaya One's Avatar
    Springfield, Mass
    bent valve
    Randy - 650 or 1000? Or do I even need to ask??
    Check out my eBay store!
    Dave - Motorace - Michelin
    Raymond NH
    bent valve
    I'm sure you can put new valve guides in it, even if Suzuki does not list them. Not sure it's worth fixing though, I'd think a used engine would be a piece of cake to get for such a popular bike. Good luck, either way.
    bent valve
    used 2second gen SV engines are very common, first gen engines are harder to find but theres still plenty
    I haven't checked into aftermarket valve guides, but they are not available thru Suzuki, even if I can find them, I still have head machining necessary , it would save only $500-600 over new heads
    Even if I do get the V-strom (1k) I still wanna get the SV going again and keep it for a daily rat bike, maybe slowly rebuild it with performance parts or a used engine, not sure
    bent valve
    That motor is shot Randy. The only reason it lasted so long is because you used it so often. If you had let it sit, I doubt it would even start up!
    I wouldn't feel bad about discarding that whole bike. It's likely not all that safe anymore. I bet the frame and suspension components are in a similar state of fatigue...
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    bent valve
    awe bummer
    It never got fast enough rebelpacket's Avatar
    Jul 2003
    Bozeman, MT
    bent valve
    135K miles is a pretty damn good run on a bike. Most people dont get that out of their cars.
    I cant believe you cant cut/press in new valve guides. Thats a pretty poor design on Suzuki's side.
    I dont know that I would throw it out either. I'd keep it in the back of the garage, and buy parts on ebay to get it back together. You dont owe anything on it, and it doesnt owe you anything. Why just walk away?
    bent valve
    If you are looking for any work to be done to the motor or looking for parts check out JD @ http://www.hordpower.com/ great guy and a wealth of knowledge.
    bent valve
    suzuki has a part # for the valve guides but it is obsolete, unless I can find someone who has old stock it is no longer available thru suzuki, they changed the head design , valve guides would have to be machined or maybe aftermarket, I haven't checked yet
    valveguides are available for the new heads
    basicly what were talkin about is marketing designed to get people to buy new bikes
  1. Bent 09 R1 Forks
    By kmf in forum For Sale
    Last Post: 12-11-09, 11:41 AM
  2. Bent rim
    By Brit-Triple in forum Bike Maintenance
    Last Post: 05-31-08, 11:30 PM
  3. Possibly Bent Swingarm
    By robs400 in forum General Bike Related
    Last Post: 02-21-08, 03:37 PM
