Results 1 to 7 of 7
stuttering bandit
    BAMF dingley00's Avatar
    Lincoln, RI
    stuttering bandit
    my bike, 1998 bandit 1200S (with vance and hines exhaust and jetted for it, but stock otherwise) has always been smooth off the line, but just this morning it was really stuttering when just taking off in 1st gear. it only has 2,300 miles on it. it would be fine once i got by 2500 rpms, but below that , just starting out off the line it would really stutter. it ran fine last night when i went to the bike night in lowell. what could it be? seems too early to have any major carb adjustments.
    2010 Kawasaki Z1000
    Jun 2005
    Re: stuttering bandit
    ha...
    I I I thththought y y y ou got rrrrrrrrobbed by a ddddddude with a st st st stutter
    you got some funk in your pilot jets?
    Sep 2007
    Middlebury VT
    Possible effect of high heat/humidity outside?
    Lincoln, RI
    i thought it was the humidity too. but today the humidity is much lower, and not nearly as warm, so shouldn't it be running better?
    2010 Kawasaki Z1000
    Jun 2005
    Pull your carbs and give them a good cleaning. If it just appeared all of a sudden my guess is that you've got something blocking something (pilot would be my guess). Pull the jets out and blast them with carb cleaner and/or (preferrably and) compressed air.
    Burn it
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    WTF??
    10 years old and only 2300 miles on it? You need to get out more. It might be the ethanol content in the gas causing a more lean condition. I had similar issues with my 97 CBR900RR. Turns out some tweaking of the carbs got her to run better. I still think she could stand some different rejetting. (It was rejetted when the Two Bros system was installed 10 years ago, but gas was much different then.)
    Might do for some fuel system maintenance.
    PM TLRMan and he'll hook you up.
  1. Best Bandit forum?
    By whynot in forum General Bike Related
    Last Post: 11-22-15, 06:39 PM
  2. Gen1 SV650 Stuttering/Bucking at high RPMS
    By DeskJockey in forum Bike Maintenance
    Last Post: 06-01-15, 05:15 PM
  3. TL1000R Stuttering at 8k rpm
    By mallis in forum Bike Maintenance
    Last Post: 07-08-13, 08:41 AM
  4. 1996 Bandit 600
    By Evil_Weasel in forum For Sale
    Last Post: 02-07-10, 05:00 PM
  5. Crazy bandit in RI ?????
    Last Post: 10-23-08, 11:51 PM
