Results 1 to 11 of 11
Drag
    GRRRRRRRRRRRRRR! capt1014's Avatar
    Apr 2006
    Ashburnham, MA
    Drag
    I put my front rim back on and now there is a what seems like alot of drag but I know tha brakes are not binding.
    Help
    http://www.facebook.com/#/profile.ph...&id=1185417660
    Live life now!....it has an expiration date!
    Friendship is like peeing in your pants,
    Everyone can see it,
    But only you can feel the true warmth.
    JACKASS hammadown's Avatar
    Hopkinton, MA
    Drag
    did you clean and regrease the axle? Maybe some dirt or debris got on it.
    Zip Tie Alley #237
    Apr 2006
    Ashburnham, MA
    Drag
    cleaned it and put a little grease on it so I didn't gawl it. I guess it really was evident when I tighten the axle as if there was to much force squeezing the axle on the bearing collars.
    Lifer mycirus's Avatar
    Aug 2003
    Whitinsville, MA
    Drag
    Make sure you put the spacer in. Look around in your garage.
    Bruce
    Apr 2006
    Ashburnham, MA
    Drag
    Ive got the spacers in.
    WoW Josephd14's Avatar
    Fitchburg, MA
    Drag
    I know on my bike I can put my rim on either way, is your tread heading the right way??????? Don't know what it does when tread goes wrong way but maybe?? anyone..
    Apr 2006
    Ashburnham, MA
    Drag
    Yup tread is headed the right way.
    The wheel was off for about a week and a half, would something have dried out?
    Or do you think the shop I went to fucked something up?
    Fitchburg, MA
    Drag
    I would say take the wheel off and inspect the bearings as best you can without taking them out, What did you have the shop do to it? anything that would effect the bearings? Brakes are not dragging right?
    Lifer ZX-12R's Avatar
    Candia, NH
    Drag
    Try reinstalling your wheel but while it is off, pry back your brake pads to see if that has anything to do with it.
    Lifer Wishbone's Avatar
    Jul 2006
    Drag
    Does your axle just get torqued down or is there a pinch of on it? If there is a pinch bolt then it only needs to be torqued to a small ft/lb generally
    Edit: this is google for you
    Front brake caliper bolts: 22 ft lb (and a dab of red locktite)
    Front axle pinch bolts: 16 ft lb
    Front axle bolt: 58 ft lb
    Rear axle nut: 83 ft lb
    You do have a torque wrench right Mr. engineer?
    Apr 2006
    Ashburnham, MA
    Drag
    I'm all set, I never notice the drag before I changed tires, but it appears that the last dlido to put brake fluid in put way to much, so the calipers wouldn't release. Drained a little last yesterday to get it down to the upper level and everything is O-Tay!
  1. And THIS is why I don't drag race......
    By Uncle Snake in forum General Bike Related
    Last Post: 09-13-11, 07:54 PM
  2. What a drag
    By eboos in forum Pit Area
    Last Post: 06-03-08, 08:50 PM
  3. Want to Drag Race Your Bike? New England Drag
    By DynoTune in forum Rides & Events
    Last Post: 08-25-07, 12:27 AM
  4. Drag
    By NinjaSwan in forum General Bike Related
    Last Post: 10-20-06, 11:37 AM
