Results 1 to 25 of 44
Bike Will Not Start
    Senior Member Jason P.'s Avatar
    Dracut
    Bike Will Not Start
    A few days ago the bike fired up fine, although I knew the battery was on its last limb. I went to get a new one today and proceeded to pop it right in.
    Still wont turn on, even tried to do a rolling start. Could it be something else like the plugs? I'm charging the battery right now in hopes the extra charge will work.
    Feb 2010
    Southbridge
    Re: Bike Will Not Start
    you need to charge a battery before installing it to do it correctly. cant open the box and install.. doesnt have a true charge
    Dracut
    kk thanks. ill wait the alotted time and see whatsup. just been so crappy out the past few days ive been antsing to ride soo bad.
    Lifer DuncanMoto's Avatar
    Where you bought the battery should have charged it for you.
    On the battery is printed the correct initial charge time and Amps required.
    Dracut
    well the battery seems to be giving her juice to start but she STILL wont start.
    check all the plugs, put new gas, checked the fuses and it wont fire up. i honestly have no idea whats wrong considering on saturday before the HID install the bike fired up fine, but thats with the old battery.
    anyone have any idea? i was wondering if there was a online manual for the 2005 Honda CBR600RR. this is driving me nuts.
    High maintenance priss
    Central MA
    Could be a whole number of things. I assume the motor is turning over just does not fire up?
    To summarize: bike was OK w/ old battery and before the HID install; you installed HID and new battery: now won't start? You may have inadvertently disconnected a plug somewhere (e.g. safety circuit like the clutch, sidestand, etc...): triple check all plugs or go troubleshooting each switch. Have you checked for spark? Are you sure you checked all fuses? Some bikes also have more than 1 fuse location...not sure specifically about the 600RR.
    Dracut
    i checked most of the fuses i can search for. going to take the fairing work off and look for maybe any connections that might have disconnected and;
    bike started with OLD battery before HID install
    i did not fire it up after the install
    tried to fire it up yday for a ride - would not start
    bought new battery - charged it for a few hours and same deal
    Just Registered drop's Avatar
    Bradford, MA
    you need to define "won't start" a little better...
    - engine turns over w/starter and sounds normal, but won't fire up?
    - dash lights up, but engine won't turn over with starter?
    - turn key but no lights on dash, no crank, nothing?
    - Jamie
    2009 K 1300 S
    i dont think the CBR's need headlights to start, that's a yamaha thing. your HID's have nothing to do with the starting issue.
    did you remove the front bodywork to install your HID system? your Tip Over Sensor is bolted right behind the speedometer, and might have been turned upside down. that would be my guess on your starting issue.
    do you have a Power Commander on your bike? if so, is the ground wire connected to the negative terminal on your new battery?
    Dracut
    Quote Originally Posted by drop View Post
    engine turns with ever everything sounding normal but WONT fire and dash lights up, all electronics light up but wont crank all the way over
    Quote Originally Posted by DBKromz View Post
    yea i did remove the front body work and placed the ballast on the frame but i will check the sensor
    Quote Originally Posted by Jason P. View Post
    did you try to start the bike with the bodywork off? more importantly, did you try to start the bike with the speedo & tip over sensor hanging off the bike (and upside down). i had this happen to me when i was replacing an HID ballast on a CBR i worked on.
    Uxbridge, MA
    Yes The CBR's DO need the headlight on to work.... at least mine does. I pulled my fuse at the last track day and ...yup you guessed it...Nothing
    Quote Originally Posted by FireboltEric_MA View Post
    interesting. i didnt think the 03-05 600rr would require it though.
    Dracut
    could sound quite bad, but i tried to find the speedo and tip over sensor, no dice but i started it with the body work off, and it wants to crank over, just doesnt happen.
    i checked them fuses, they were good, maybe it could be the spark plugs, which ill prob check next.
    Uxbridge, MA
    My bad...I did not see that part... Going back to my hole in the ground now....mine is a 2009
    Dracut
    LOL well i tried the flooding start method. SHE FIRED up, but then i let her warm to 125 degrees, revved a bit and she died again. iono i was MAD ecstatic then kinda sad, lol.
    Uxbridge, MA
    I was just gonna post the flooding start routine....
    i would let it run until warm though...220 deg.
    Uxbridge, MA
    Did you try this yet?
    There's a "test plug that you need to ground, and count the flashes of the FI light. The plug is under the seat, right side of the bike, near the ECM , at the right rear of the battery. There are 2 wires to the plug, and you need to jump them, then turn the key "on", with the kill switch on "run".
    If there's a code, the FI will flash your code(s). Count the flashes.
    There's long blinks amd short blinks.
    Long = 1.3 seconds
    Short = .5 seconds
    If you have a long blink, the 3 short ones.....that's 13.
    A long blink = 10
    A short blink = 1
    9 short blinks = 9....and so on.
    Let us know....
    CODES:
    0 - bank angle sensor, ECM, PGM-FI fuse
    1 - MAP sensor
    2 - MAP sensor vacuum hoses, or sensor itself
    7 - ECT sensor poorly connected or open circuit
    8 - TP sensor, TP senspr wiring
    9 - IAT sensor connection, or open wire
    10 - Baro sensor, or connection, or wiring
    11 - Vehicle speed sensor, or connection or wiring
    12 - #1 injector connection, or faulty injector
    13 - #2 injectior connection or faulty injector
    14 - #1 connection or open/shorted circuit
    15 - #2 connection or open/shorted circuit
    18 - Cam pulse sensor, connection or loose sensor
    19 - Ignition pulse sensor, connection or loose sensor
    20 - faulty E-PROM in ECM.
    Uxbridge, MA
    The pump and relay would be my next test...
    What you need to do is find your fuel pump relay ( it is located on your left intake tube, there are 3 relays, it is the one closest to the front of your bike) Find the wires coming out of it. There will be 1 spot with 2 black wires coming out. These are your bypass wires. 1 goes to the back of your bike to an unused connection. The other goes to your fan relay. The easiest way will be to slightly splice the black wire that is not connected to your fan relay. then splice the small brown wire (negative). Hook your batteries positive up to the black wire and the negative up to the small brown wire. The easiest way is probably to use some little clamp wires. This should turn on your relay and you will hear a clicking noise and your fuel pump will turn on. The only down fall is that since you are bypassing your bike computer that you will have to manually turn your fuel pump off by disconnecting the wires. That will at least tell you if your relay and pump are working.
    Uxbridge, MA
    this is assuming you have done the simple things like check wires, plugs etc..etc..
    Dracut
    well the fuel pump works. i can hear it turn on when i start the key to the ON position
    who knows
    I THINK I KNOW WHATS WRONG!!!!!!
    It's the same issue I was having with mine Jason... The sevice connector (basically a ground box) has a bad ground.
    Let me guess, your dash comes on but not 100% on, no headlights, and your blinkers are on but solid and not blinking?
    I THINK I KNOW WHATS WRONG TOO!!!!!!
    It's a Honda..... JK....
    speedo = speedometer
    do you have the service manual? i have one in PDF on my webserver if you need it
  1. Bike won’t start
    By Momoney7878 in forum Bike Maintenance
    Last Post: 11-24-21, 12:33 PM
  2. Dirt Bike Bump Start with another bike
    By nt650hawk in forum Dirty Bastards
    Last Post: 12-24-15, 06:31 AM
  3. bike won't start
    By G21forme in forum Bike Maintenance
    Last Post: 05-14-09, 12:11 PM
  4. Bike won't start
    By Punjistick in forum General Bike Related
    Last Post: 07-03-06, 01:04 PM
  5. bike will not start
    By double agent in forum Bike Maintenance
    Last Post: 01-08-06, 08:10 PM
