Results 1 to 25 of 28
bike wont start, any ideas
    who knows
    Sooo, my bike been sitting in the driveway for the last couple weeks since I broke the foot. I've been starting it every coupla days and did take it for a small ride up the street to warm the chain once to lube it after I gave it a good wash.
    The other day I went to start it and when I turned the key on the fuel injection wont prime the fuel system and the bike wont start, the head light is off and the rear blinkers are both on solid as well. Everything else is working fine though.. the dashboard comes on and the starter works when I turn the on/off switch to on and hit the start button
    I was having this happen to me at the beginning of the year everytime the bike got wet and someone from here recommended putting Di-Electric grease on all the fittings which I did and the bike seemed fine. After I did this I even tested it pretty well by getting caught in a couple of the monsoons and the bike got pretty wet but always started back up.
    I already took all the plastics off (except the front fairing) and Di-Elec. greased all the fittings again and even put some in the opposite sides of the connetors and I have had no luck getting it started again.
    What the hell do I do now? Any idea's? Are there more connectors behind the front fairing I should grease up? Every morning there is dew on the bike, I'm thinking this might be the cause of my issues but now that the bike wont start I can't get it over to the barn I store it in to keep it dry.
    Lifer burnham's Avatar
    Apr 2006
    massachusetts
    Re: bike wont start, any idea's
    A little shot of WD-40 in the connectors will help get the water out, it may be a little quicker and easier than packing everything with grease. At least for trouble-shooting, then you could go back and get things a little more water-proof after.
    Meriden, Ct
    It's done. Throw it out.
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    I am betting one of the wire/connector connections is rotted through
    When you did your thing you pushed them back into contact
    wire by wire give them each a tug one may pull out
    sometimes the insulation may still be grabbing
    Obviously start with tracing back from the fuel pump if it doesn't wake up
    follow pump, relay, tip over etc.
    Glen Beck is John the Baptist
    Old and Slow Sheppo's Avatar
    Westford, Ma
    I'll give you $10.00 cash money
    check the connections, kickstand and clutch switches
    Posted by Jane in BoxChat
    I recently had a no start problem with my V-strom, the connector from the main wire harness to the kill switch was corroded, just a matter of unplugging it, cleaning it up spraying with wd40 and reconnecting it
    who knows
    Right now i am in the process of taking the front cowl off. it's the only place that I haven't opened up yet.
    I did notice after I started it when I washed it a lot of water was stuck in the radiator fins and as it heated up there was a lot of steam all over the inside of the dashboard area which is why I am thinking to try takin the the front cowl off and seeing what type of connectors are under that.
    I also took my battery out and poped off the cell covers and noticed I don't see any acid covering the battery plates. Is it possible that the battery is too dead to start the Fuel Injection system but powerfull enough to run the starter. I tried starting it many times and the starter seems to be working fine. just no gas getting to the engine.
    Is putting Di-electric grease in the connection going to achieve the same affect? also i haven't found connectors that are corroded at all?
    Check connection to the headlight relay in front of lights after.you take front cowl off. I'm still betting its the connector on the left with the big rubber boot over it.
    Arlington MA 02474
    Yes. It might crank but not have the juice to fire properly. Do you have a battery tender?
    Also, I had one of these batteries in a Ducati -- fabulous:
    http://www.batterymart.com/c-odyssey-batteries.html
    -Kurt
    No fuel pump prime=bad connection.
    who knows
    Thank you for the reply's
    so there are more connectors on the inside of the front cowl behind the headlight and dashboard assembly? Or are you refering to the grey and blue connectors under the left air dam cover? I also took the gas tank cover off and got 4 connectors that I missed the first time and when i saw them I was thinking here it the problem but they didn't look corroded at all and were not damp. I greased them up and put the tank cover back on. still no go.
    I haven't taken the front cowl off yet but that is the next step. I have Hondarider stopping by later to give me a hand since it's hard to manuver with the broken foot and all and I don't want to drop that bitch on the ground. I also thought i could use his relay bar to confirm a relay issue or not since he has an 06 RR.
    I do have a charger that I hooked up for the last couple hours and the battery was only slightly discharged because the starter sound did get a little stronger but not much so I think it was only from trying to start it for the last couple days.
    Don't keep trying to start it. If the fuel pump has not primed it won't fire and it won't be putting out a spark even. The issue is the check system for ignition has a bad ground most likely. It is in the blue and orange connectors under the left side fairing. The ones with rubber covering them. If it isn't throwing an fi code then it is probably this connector or a poor ground (located just below the relays on the left side)
    Re: bike wont start, any ideas
    my V-strom wouldn't start friday
    acted like kill switch was on but wasn't
    quick call to dealer, they steered me to the kill switch connection at the main wire, disconnected it, cleaned it wwith wire brush best I could, sprayed with wd40, reconnected, bike started right up
    Murph Murph's Avatar
    Aug 2009
    Carver,Mass.
    Check the killswitch on the kickstand too...do you run fuel stabilizer? Doesn't take long for this ethanol crap to turn bad...
    The more people I meet, the more I like my dogs.....
    who knows
    Quote Originally Posted by Murph View Post
    didn't have fuel stabilizer in it but have been starting it every couple days and I stated it the morning before it didn't work. it does have a full tank of gas, if i add fuel stabilizer will fix the fuel if it is the issue?? Once i get it started I plan on driving it enough to empty the tank.
    I just don't see how bad fuel would somehow trigger the electric compnents from booting up the FI...
    I just got the front cowl off now and took it apart and still don't see any signs of corrosion or signs of water on the connectors. going to di-electric grease everything and put it all back together and see what happens. don't think it's going to work though?
    I'm thinking it might be the relay, if it's not working after I put the front cowl back together and on i'm might just going to jump the relay to see if that is the issue. unless i can get hondarider over to swap out the replays for a minute.
    what a pain in the ass. my foot is finally feeling better and I was planning on riding around the Bolton area this weekend because I am sick and tired of being on the couch
    Aug 2004
    Baltic,CT
    Yes battery fluid should MORE than cover plates
    Add distilled water or run off city water not well water
    look again after 10 minutes. If battery dry it is a bad sign about your charger system unless its 4 years old. Eliminate problem by jumping from your car.
    Note if when cranking battery voltage goes below 9V then electronics go to sleep and no go. Bump start in 3rd gear
    who knows
    OK I got the bike started but only by jumping the engine stop relay and when I do that the FI light comes on an the fuel pump primes and the bike starts but when I replaced the engine stop relay with the radiator fan relay I still get nothing. also the headlight still wont come on.
    I feel a lot better knowing I got the bike started and the fuel pump is working since they are around $400 bucks.
    But I am confused now to what my actual problem is? should I take apart the kill switch and clean that up see if there is some issues in there, corsion or something?
    these electric problems are beyond me?
    Aug 2004
    Baltic,CT
    I think the headlight is the clue
    Follow back the power because I imagine its
    hotwire
    fuse
    ignition switch
    handlebar high low
    headlight
    no voodoo electronics
    I don't think it goes through the kill circute etc.
    The battery power should go into one of these then not come out
    that's your problem
    Spidey sense says ignition swithc
    who knows
    Quote Originally Posted by richw View Post
    Spidey sense says ignition switch
    How do you test the ignition switch to see is this is the culprit Spidey? I'm assuming I need some sort of electric measuring device? Time to by a multimeter?
    Aug 2004
    Baltic,CT
    Ye rabbit you need one
    Walmart has a nice cheap ones for 10 to 15 dollars
    If your building tools a small 12v test light is a little faster and shows some current
    capability as well.
    Set on low volts DC 0 to 24 usually
    Black wire goes to frame or neg on battery
    follow down the red plus looking for 12V
    get to switch.... there will be a hot side from the battery
    turn the key the cold side should become 12V etc.
    Also nice to have jumpers wire with small aligator clip on both sides
    hold neg onto battery radio crap
    to diagnos you can "JUMP" around a component to provide the voltage after it.
    Old indian trick get a medium sewing needle
    you can push it throught the wire insulation and then test voltage of a wire by contacting the needle
    NorthShore
    If your building tools a small 12v test light is a little faster and shows some current capability as well.
    Well, don't go buy one, Scoobs, I found I own three of them when I went through my stuff and packed up from Virginia to come up here. If you need it in the next couple days, it's yours. Flee! I mean, free..
    Steve, I will bring mine tomorrow. You have a maintnance manual for your bike?
    Lifer akira700's Avatar
    Apr 2005
    in the city
    I'd start there. How old is the battery? More than 3 years old?
    Try a new one. Or get it stress tested at a shop.
    2008 Honda CBR 600RR
    who knows
    Quote Originally Posted by akira700 View Post
    Hey everyone, thank you all for your help and idea's....
    I figured it wasn't the battery because when I jumped the engine stop relay the bike starts like nothing was wrong...except for the fact that the headlights, and front blinkers, ect... are not comming on.
    Degsy came over the other day and we went throught the whole electrical system and found that the Bank Angle Sensor is junk. We jumped around it and viola.... everything worked including the healights and the rest of the front end shit
    Degsy order me a new one and saved me a bunch of greenbacks all around.
    Degsy is the man!
    Lifer DuncanMoto's Avatar
    Wirelessly posted (BlackBerry9000/4.6.0.167 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102 UP.Link/6.3.1.20.0)
    If there's a dead cell there may not be a prime.
    If you,re near us I have a tester, just bring the battery by. No charge.
  1. Bike wont start code _C34
    By Drewgrace in forum Bike Maintenance
    Last Post: 03-09-15, 06:48 AM
  2. BIKE WONT START
    By dj 96yzf750 in forum Bike Maintenance
    Last Post: 07-23-09, 05:49 PM
  3. bike wont start :(
    By daviid in forum Bike Maintenance
    Last Post: 05-17-09, 11:29 PM
  4. Bike wont' start after winter storage
    By Bluesman in forum Bike Maintenance
    Last Post: 04-11-09, 09:50 AM
  5. Bike wont start?
    By Rclassic03 in forum Bike Maintenance
    Last Post: 08-21-08, 06:10 PM
