Results 1 to 25 of 30
Undoing front sprocket nut with bike in gear
    Lifer wiggeywackyo's Avatar
    Feb 2009
    City
    Slow brain moment.
    I forgot to loosen the front sprocket nut while the wheel and chain were still on the bike. Now the old chain is covered in cat poo and there's a new sprocket on the rear wheel.
    How risky is it to torque against the nut while the bike is in a really high gear?
    LRRS 878 Clapped out Gixxah
    Lifer DuncanMoto's Avatar
    Re: Undoing front sprocket nut with bike in gear
    You will not hurt the engine if that's what you mean.
    You may turn it, but you won't hurt it.
    You could just install the new chain and tire and then losen the nut.
    Feb 2009
    City
    It's a 520, I haven't checked if it will fit on the old 525.
    I'm more worried about hurting the transmission internals.
    Quote Originally Posted by wiggeywackyo View Post
    Won't hurt it. You have about 1/7th horsepower. Your engine exerts a little more than that on the gears...... The 520 may fit on an older worn sprocket enough to hold it.
    Dec 2003
    Ma
    No you won't. What do you think all the power between the engine and rear wheel are transferred through?
    Feb 2009
    City
    OK, you guys talked me into getting a bad ass impact gun then. Darn.
    HAHA!!!
    YEAH!!!
    BTW - Make sure the ignition is off and put it in 1st gear.
    You could probably do it by hand depending on compression.
    Member ecd2004's Avatar
    Apr 2010
    New Hartford/Colebrook, CT
    impact driver is a godsend. i tried to do it by hand but couldnt even budge it
    Feb 2009
    City
    Quote Originally Posted by DuncanMoto View Post
    HAHA!!!
    YEAH!!!
    Don't you mean 6th?
    I've been meaning to buy an impact driver for a while anyways. Someone done stolded my breaker bar.
    Lifer legalspeed's Avatar
    Somersworth, NH
    6th? dosen't matter, put it in gear and throw a board through the back spoke/swinger. Crank on the impact, make sure you are going in the losen direction, and check for a washer bent over the nut face (to lock in place).
    LRRS\CCS\WERA #486
    so/so mechanic... NeverlosT's Avatar
    Jul 2008
    South Kingstown, RI
    try shouting at it too
    Don't Fake the funk on a nasty dunk.
    NEW STREET/TRACK: 2007.5 Aprilia Tuono
    STREET/TRACK: '08 CBR600RR (SOLD)
    '07 VFR800 (SOLD)
    Just Registered 13's Avatar
    Dec 2003
    Auburn, NH
    With no chain on it, you'll want to usue 1st. The engine will have the most mechanical advantage over you in the lowest gear.
    One of the former LRRS #13's
    http://www.facebook.com/ChrisWatt762
    JT42
    TWINS! xrocket21's Avatar
    Central Maine
    Quote Originally Posted by 13 View Post
    I feel like this isnt right
    Try pushing a bike in 6th then try it again in 1st. You'll see.
    Dec 2003
    Auburn, NH
    Park your car on a hill in top gear, then in 1st. Tell me which gear allows gravity to overpower your engines compression.
    JT42
    Lifer Expat's Avatar
    Mar 2007
    First!!!!
    Obviously some people here have never bump started a bike!!
    I never use the transmission to do this...
    Board through the wheel and a big bar on the end of a meaty wrench! Works every time and no screwing around the rear brake, transmission, etc.
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    They make a tool for that job ya know
    Dec 2003
    Auburn, NH
    Quote Originally Posted by 35racer View Post
    Neither do I. But he has no wheel or chain on the bike.
    JT42
    Bullshit meter pegged scottfromboston's Avatar
    Oct 2009
    Maynard,MA
    I made the same mistake as you; it came off of the SV in first, by hand (a quick bump with a breaker bar). Easy. Maybe too easy?
    ~Scott
    2020 SMC-R
    I personally wouldn't put it in gear (no need to)....but if you just hit it with a impact gun its comes right off...
    Quote Originally Posted by Pigman
    Pigman speaks truth. I personally don't like to run an impact against the tranny and motor.
    I can see it now.....Jack has his wheel with a board sticking thru it and 15 feet away is his bike with the front sprocket still on it.
    "Thanks for the suggestions, everyone, but the sprocket nut still doesn't come off...."
    Uxbridge, MA
    Just get a couple guys to do it.
    Pigman has the right idea!
  1. Need to borrow/buy 1st SV front sprocket
    By tsorfas in forum Pit Area
    Last Post: 08-26-14, 12:53 PM
  2. Switching out front sprocket
    By Trickniner in forum Bike Maintenance
    Last Post: 06-20-11, 03:28 PM
  3. front sprocket nut
    By Truth in forum Bike Maintenance
    Last Post: 09-06-08, 06:28 PM
  4. Front sprocket help
    By G21forme in forum Bike Maintenance
    Last Post: 07-18-08, 01:28 PM
  5. Afam Front sprocket
    By KillahTillah in forum General Bike Related
    Last Post: 06-09-08, 07:38 PM
