Results 1 to 25 of 25
Another brake problem!
    60% squid duganc1717's Avatar
    Dec 2008
    Framingham
    So I bought a TLR yesterday and I noticed a slight brake pulsation. The closer to home I got (40 mile ride) the worse the problem became.
    After a few hours I took the TLR for a quick ride and you can actually see the dip and rise when you apply the brake @ slow speeds?
    Mainly when you are rolling up behind a car in traffic or parking lot around 20-25mph?
    The bike is suppose to have new rotors and pads and brake fluid. Also is there any type of brake fluid that is a dark color?
    The clutch and brakes are all suppose to have new fluids but, it looks pretty dark through the reservoirs.
    Raymond NH
    Re: Another brake problem!
    Congrats on the new bike!
    New brake fluid is never dark. New rotors don't have runout. Sellers often lie, I'm guessing you don't have new pads either...
    Lifer JohnnyV's Avatar
    Westborough, MA
    Lifer DuncanMoto's Avatar
    Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102 UP.Link/6.3.1.20.0)
    Put the bike on a stand and check the rotors and wheel for straightness.
    I have recantly seen a wheel with crap on the rotor mount surface that caused that.
    I have also seen a bent rim that had been staightened' but aparently not quite perfectly.
    Dec 2008
    Framingham
    Dec 2008
    Framingham
    You can see in the pic of the controls the color in the clutch/brake reservoir's. Almost looks purple and all three look the same.
    I'm sorry!
    Carry on
    That's the new grape flavored brake fluid. tasty.
    I'd try cleaning the rotors well and then using a 400 grit sandpaper to put a fresh crosshatch on them and see if it still does it. Its often just build up of oils and crap.
    Derry NH
    DOT5 is purple.
    Senior Member Pestilence's Avatar
    Salem MA - Soon.. Sandy Eggo CA!!!
    Quote Originally Posted by Eric Baker View Post
    DOT5 is purple.
    and is NOT COMPATIBLE with any other kind of fluid. Read this.. DO NOT MIX WITH DOT 3 OR 4 or you'lll ruin the seals.
    If it is in fact 5 and purple, it's silicone based and perfectly fine to keep using. It's a Hydrophobic fluid in that it won't absorb water like the 3's and 4's. It will however absorb air so requires a little extra bleeding to remove all the air from the system.
    -John
    "It's more fun to ride a slow bike fast,.. than to ride a fast bike slow."
    07 Husky SM510R
    Dec 2008
    Framingham
    Pretty sure it's not purple! The clutch reservoir actually had sludge @ the bottom.
    Posting Freak
    Oct 2009
    Southern RI
    looks like motor oil....
    Edit: Have you touched the stuff to see what color it is? Or maybe dip a paper towel in it and get a pic? But it sure is a nice looking bike.
    KAWASAKI RULES WOOOOO!
    if it's DOT3 or DOT4 & it needs a fluid change, bring it by this weekend & i'll help you out.
    The pulsation could be caused by either a warped disc, or parts of the disc that have some type of residue on them such as fork oil, grease, etc.
    Before I replaced my fork seals and after they started leaking, a little bit of fork oil got onto the brake assembly. The oil is gone but I think some of it may have soaked into the brake pads because the finish of the rotors is dark and burnished looking, unlike what it had been until the leak started. My brakes don't pulsate but they do seem to require much more lever effort than they used to.
    You can almost see a dark area on the rotor in the right side shot of the bike, could just be the photo. I plan on disassembling my front brakes, scuffing the rotors, replacing the pads and also rebuilding the calipers and maybe the M/C over the winter. You might be able to just try what Paul said and cleaning the rotors and that could solve it. The brake fluid doesn't have anything to do with the pulsation but definitely flush it with fresh stuff.
    Nice looking bike, BTW.
    Member gixerhp's Avatar
    Jun 2009
    Nashua
    Quote Originally Posted by Mad Max View Post
    The Tokico calipers, are know for sticking, especially on the Busa's!
    If there is new rotors on the bike also i would suspect that the calipers are in need of being rebuilt also!
    I just rebuilt 2 sets of these for friends!
    Performance: 1397 JE bigbore, Dual Intake cams, Adjustable cam spockets, Sm air box mod,Pc3 usb,Ingnition box w/hub, and Lcd screen, Hindle stepped race header, Dual Fans, 24 volt starting
    Suspension & Brakes: Ohlins road and track forks, Ohlins rear shock, Sprint top mount dampner, PRM top clamp, Dymag Carbon mags, Brembo HP rotors, Brembo Hp radial calipers,
    Show & GO: Topgun undertail, Libertek led lights, Pazzo lever, PMR Switches & Kill,PMR cover. Revolution Custom Paint, Harris Grips.
    that literally looks like used motor oil in the brake resi! wtf?!
    I ride a custom fighter!
    Quote Originally Posted by gixerhp View Post
    how much was the caliper rebuild kit? how long did it take? this is something i'm interested in doing this winter.
    Jun 2009
    Nashua
    Quote Originally Posted by DBKromz View Post
    The seal kit for both calipers is around $60 my cost, then a hour of labor, if the calipers are off the bike!
    Meriden, Ct
    Quote Originally Posted by duganc1717 View Post
    Don't ride near your house... Problem solved.
    random thought, have you tried greasing the pivit on the lever
    Dec 2008
    Framingham
    Jim thanks again for the help. Brakes feel a lot better than they did.
    i'd replace those pads though. i'm getting a set of Performance Friction pads "99" application.
    if you wanted to upgrade, get an 05+ GSXR master cylinder & stainless brake lines to fit. the M/C would be around $50 used & about $90 for the lines.
    couldn't hurt to rebuild the calipers over the winter too, if you'd be replacing your lines.
    Jun 2009
    Nashua
    All three makes for a great upgrade!
    i'm getting a 19RCS with a caliper rebuild & Performance Friction pads to use on my SS lines and galfer wave rotors
    Jul 2008
    Marlborough Mass
    oh arnt you special
  1. Rear Brake Problem
    By odduc in forum Bike Maintenance
    Last Post: 07-28-06, 03:57 PM
  2. Brake Bleeding problem...
    By Hamburgler in forum Bike Maintenance
    Last Post: 05-16-06, 08:01 AM
  3. Brake light problem
    By Dannyboy in forum Bike Maintenance
    Last Post: 05-23-03, 09:33 PM
