I think it may be time to replace my front discs. Toward the end of last season, I was getting a bit of a shake/vibration while braking harder than normal. I took a look around and people say stock/stock style discs are better than those wave ones in performance and longitivity.
1. What else could cause shake/vibration
2. Do I have to buy new discs or coule I someone remedy the stock discs
3. Where else could I buy OEM/OEM quality discs for less than $350/disc that I've found online.
Shake in the lever or shake in the bars?
If I remember right, it's in the bars
you can also send out your stock ones to be straightened for like $20-30. I was putting my bike on the front stand this summer and it slipped off and the rotor got the brunt of the bikes weight and is rubbing like an asian massager. I'll be pulling mine off and sending them to this guy in the spring.
Wills Rim Repair - http://willsrimrepair.com.... i know this says rim repair but he also straighten's rotors...
Also if you're bike is around 5-6 years old, a caliper re-build is very simple and will fix sticky pistions if that is the issue and not the rotor. I will warn you though, bleeding brake fuild through totally empty brake lines and calipers can be a wicked biatch to get all the bubbles out ont he first try. took me a little bit of bleeding... riding.. then bleeding to get all the air out.
I've sent rotors to Will's before. he does good work and for only $10 its worth it.
you're right about filling empty calipers and lines. if I had to do it again I'd get something like this http://www.sears.com/tektro-hydrauli...7&blockType=G7 and fill the calipers first before putting the lines on.
LRRS Am #331
With cars, a lot of "warped" rotors that generate vibration is just uneven build up on the rotor surface. Fixed by a burn in (aka bedding). I imagine the same is true with bikes?
nedirtriders.com
Sometimes, it depends... air in the system or a sticking piston in the caliper can cause vibrations, as can deposits. Typically some scotch brite and a good ride with hard breaking can tell you if it's deposits on the rotors. Unfortunately I have the same issue and am going with new EBC XC fully floating rotors. You can also try a floating button kit.
