Results 1 to 23 of 23
R6 caliper rebuild
    Lifer Dip Dungles's Avatar
    Chilling with Dick Hurts
    R6 caliper rebuild
    Looking at rebuilding my new calipers before I throw them on for the season. I have been looking at online fiches for a few days and I think I know what I need, but want to be absolutely sure before I pull the trigger.
    09 R6 calipers and here is the fiche with the parts I think I need...
    http://www.parkwaycycle.com/fiche_se...009&fveh=50766
    I need # 5,7,16 and 18 right? If that's the case why the hell are they so damn expensive? They are freaking seals for christ sakes. Any one have a better deal then that?
    Shannon
    Re: R6 caliper rebuild
    GSXR caliper seals are like $40.
    Shannon
    Wirelessly posted
    Just take the calipers apart (you will need a special tool to open them on the R6 calipers) and clean them and reuse the existing seals. They are probably fine.
    Make sure you don't turn them inside out when you reinstall them and lube them with fresh brake fluid.
    ...or dont bother
    it's for a street bike, right?
    Yes street bike. I have pretty bad drag on my stock calipers and do not want the same issue once the new ones go in. Ya know do it right the first time kind of deal.
    Degs I do not have that tool. What's the price on one of those or if you have it could I throw a few bucks your way to do it? I do not have a compressor to get the pistons out anyways.
    Shannon
    without the compressor, then it cant be done.
    he only has Honda & GSX-R special tools.
    i've never known anyone to rebuild R1/R6 calipers....race or street. i think you'll be fine without touching them.
    just install them, take the pads out, pump the lever a few times to push the pistons out a little & clean them with a toothbrush w/ brake cleaner on the brush.
    it's what i do every other race weekend on my GSXR calipers
    and all GSXR'S seem to have a bit of DRAG FYI..................except frenchy's bike WHat a D BAG...
    I think you would be fine without touching them. I still haven't touched my 06 calipers and they are still great.
    Hey I'm down with saving a few bucks. Next question then. I ordered new brake line bolts but didn't receive washers. What can I use instead or do I have to order specific crush washers?
    Shannon
    i reuse crush washers all the time, even though you're "supposed" to replace them every time
    Wirelessly posted
    Like Jim says. Clean them well and install them. They are much better than gixxer ones.
    I don't have the special tool. I can get hold of one if needed though.
    Haverhill, MA
    Just $0.02 that I heard from a local race mechanic regarding cleaning calipers. He actually reccomends not using brake cleaner to clean the calipers, says that the brake cleaner can actually swell the seals and contribute to more drag and stiction between the pistons and seals, with ensuing pad to rotor drag. His suggestion was to use simple green or some other type of biodegradeable cleaner that isn't quite as agressive as the brake cleaner would be. Simple green definitely works better than I thought it ever would and my brakes work very well without the drag that I have seen when using the brake cleaner in the past.
    Joel
    Wirelessly posted
    Quote Originally Posted by tls25rs
    Joel
    I often thought about that. Seems wrong to use brake cleaner so close to those seals.
    I have heard the same thing from MotoJoe on gixxer.com. I used Simplegreen on my old CBR and that worked very well.
    Shannon
    Apr 2011
    NH
    I've seen cans of brake cleaner specifically state not to use it on the rubber parts.
    Tim
    LRRS #44
    Superbike Services 44
    i use brake cleaner to brush my teeth
    Jun 2005
    Also, if you have radial calipers make sure you pump up the brake and hold the lever while the bolts are loose and THEN tighten the bolts.
    Wirelessly posted
    Quote Originally Posted by timmyho414
    Those seals aren't just Any old rubber though. They have to take brake fluid without swelling. Still, brake cleaner is pretty solvent.
    09 any idea of miles but I would say throw them on and go...
    You get the spacers from that Zorian guy?
    No idea on the miles. And yes I have the spacers
    Shannon
    Boinnnnnngggg no lie
    Pads?
    Versahs
    Shannon
  1. Caliper issues
    By jewfzr in forum Bike Maintenance
    Last Post: 09-14-10, 11:55 AM
  2. reinstalling a caliper
    By breakdirt916 in forum Bike Maintenance
    Last Post: 05-17-10, 10:36 PM
  3. wtb \\\\\ BRAKE CALIPER /////
    By Bandit12k in forum Wanted
    Last Post: 03-07-10, 11:24 PM
  4. WTB 6 pot brake caliper
    By Bandit12k in forum For Sale
    Last Post: 12-07-09, 10:17 PM
  5. WTB 94+ EX500 front caliper
    By Pittenger5 in forum For Sale
    Last Post: 06-26-08, 11:23 AM
