The top of my master cylinder and every brake fluid bottle always says to use brake fluid from a 'sealed container'.
I can understand that you don't want to leave the top off the bottle for a month then put it into your reservoir. But if you have the cap on tight, and a few weeks pass between doing the brakes on a couple of bikes,can the brake fluid actually absorb enough moisture to be a problem for the second bike? Is it really open and discard whatever's leftover?
Thnx.
DanG
- Blaise Pascal
Sounds to me like you'll be fine.
I've used two-month-old-open-but-capped brake fluid and have experienced no noticeable deterioration in braking quality.
a Sell more brake fluid
b could absorb water but probably not
i chuck it after like a year
Glen Beck is John the Baptist
What fluid are you guys using?
Just some dumbass
