Results 1 to 9 of 9
Brake question
    Lifer Pittenger5's Avatar
    Austin
    Brake question
    Ever since the KTMs little "incident" yesterday Ive noticing some weird brake dealies (then again, I never noticed before, but it could be in my head) I was getting SOME brake fade before its incident, and really noticeable after. However, after when I grabbed brake some fluid would come out of 2 little breathers I guess in the cap. I pulled the cap off, and the fluid level was low so I filled it to the fill line, put the cap back on, and squeezed the brakes again and fluid is still coming out of the "breathers" or whatever they are. Little notches cut on either side of the cap. I dunno if its just excess fluid caught somewhere from being on its side, or if theres a problem. What should I check, or should it be alright after a while.
    Zip Tie Alley #505
    Re: Brake question
    Could be the diaphragm is blown. Hard to tell from here.
    Wirelessly posted (BlackBerry Curve: BlackBerry8330/4.5.0.160 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/104)
    I suggest you stop being a faggot. You're in the back seat of a cab
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: Brake question
    try flushing it through, cleaning and checking all the connections. the little incident might have just upset it a little. or ride it and see if the fluid goes down, something might have cracked or loosened..
    Posted by Jane in BoxChat
    Meriden, Ct
    Re: Brake question
    Brake systems don't have "breathers" or anything that would allow air or fluid to pass in or out of the system. Something is wrong my brotha.
    Re: Brake question
    Ummm Noel, yes they have "breathers" however it's more of a relief passage than anything.
    Every single hydraulic braking system I've ever seen has a passage of some sort near or part of the resevoir cap which allows the diaphragm to extend as the pads wear out and more brake fluid is required at the caliper.
    Infected Slyder's Avatar
    Concord, NH
    Re: Brake question
    My resevoir has has a plastic washer that sits on top of the diaphragm, between it and the cap. Maybe replace the diaphragm and that washer, if yours has one? Maybe it's cracked or warped.
    Is there a check valve or something in the master to prevent the fluid from back flowing into the resevoir? Maybe that or something is broken, if it exists. I can take the cap off and pull the lever to the bar without worrying about fluid over flowing out of the resevoir
    .... naked-daytrader's Avatar
    May 2007
    Re: Brake question
    Quote Originally Posted by Butcher Bergs View Post
    And Noel wants to be my latex salesman?
    CCS|LRRS EX#49
    2006 KTM 560 SMR - 2006 Yamaha R6
    LRRS Rookie of the Year 2002-2006
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Re: Brake question
    Start with a good bleed including banjos
    sounds like air
    check for rotor damage as if its swash plating (not running true) it can act like a pump
    Glen Beck is John the Baptist
  1. brake bleed question
    By backinthesaddle in forum Bike Maintenance
    Last Post: 11-14-21, 03:05 PM
  2. Rear brake question
    By Drewski in forum Bike Maintenance
    Last Post: 05-10-15, 10:27 PM
  3. Galfer brake pad question.
    By Ericthejet in forum Bike Maintenance
    Last Post: 03-18-10, 09:43 AM
  4. question about brakes and brake hose
    By jeffsv in forum Bike Maintenance
    Last Post: 03-19-08, 02:35 PM
  5. Brake line question.....
    By 13 in forum Pit Area
    Last Post: 04-12-07, 04:57 PM
