So I want to get some new brake lines, because I heard steel braided brakelines make a huge difference in the feel of your bike. Goodwrench has kevlar braided brake lines..worth it?
How hard are these beasts to install?
What brands are good?
--HBerry
LRRS# 285 - Retired
04 ZX-6R
88 EX500 - Broke
Braided lines are simple to install, however make sure to use six point wrenches for the banjo bolts, and flair wrenches for the hydraulic fittings. Open end wrenches tend to round off the fittings. While you are there, a new set of pads wouldn't hurt. Bleed the brakes, and you are done.
IMO braided lines are overkill for average street riding. That said, I have them installed in my car (ironically the entire set was less expensive then just the front rubber lines). They do take all the play out of the pedal (it's like stepping on a brick).
SSearchVT
I don't think so Scott. I can say that I noticed a huge difference after I installed mine SS lines. I put HH pads in too - AMAZING.Originally posted by SSearchVT
It's always nice to be able to stop on a dime. - just remember to take a few to get used to them....
Bras cause cancer.
So who wants to help me install these? I have to head up to stoners house sometime soon so we can drill a fairing...![]()
--HBerry
LRRS# 285 - Retired
04 ZX-6R
88 EX500 - Broke
BRAKE LINES!!!!
--HBerry
LRRS# 285 - Retired
04 ZX-6R
88 EX500 - Broke
Uhuh, and then you'll want new pads, I did the stainless/sintered thing and I'm pretty sure it was the pads that gave my brakes most of their newfound power, not the lines.Originally posted by HBerry
BRAKE LINES!!!!
And then when your nice fancy pads start chewing through your stock rotors, like mine already seem to be doing after only three trackdays....
You'll want aftermarket rotors.
Might as well get 'em while they're cheap.
Okie Dokie!Originally posted by Honclfibr
--HBerry
LRRS# 285 - Retired
04 ZX-6R
88 EX500 - Broke
I'll help ya mike, it'll take us like 1/2 hour, maybe hour if we really take our time.
i dont live too far from ya. but it will have to be next week, my weekend is all booked up already and i have to work late tonight.
Brent LRRS #772
2006 KTM 560 SMR
Hey Will... Based on this I don't think I would classify you as "Average"...
SSearchVT
hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
http://www.calsportbike.com/cgi-bin/...x.cgi?pid=1364
$180 for everything.... Galfer lines, gold banjo bolts, gold banjo fittings, double bleeder banjo bolt (whatever the hell that is) and Galfer HH pads.....
A double banjo bolt is a banjo bolt with two holes for banjo fittings. These are required for a two line system like most aftermarket lines are, where both lines go directly to the master cylinder rather than to a junction near the steering head like the stock lines.
A bleeder banjo bolt is a banjo bolt with a bleed nipple at the end of the bolt, so that you can bleed the air out of the top of the lines as well as from the traditional locations at the calipers. You can always bleed the air out of the top by applying brake pressure and cracking the master banjo bolt with a towel wrapped around it, but these make things a bit easier / less messy.
You're paying extra for the bleeder banjo, the stock kit will come with a double banjo standard. Bleeder double banjo bolts (the proper term, there's only a single bleeder, there's two banjo fittings) are about 10 bucks from lockhart, iirc.
ah, i gotcha
So is this kit a good deal, or should I just get braided lines and then some new pads?Originally posted by OreoGaborio
--HBerry
LRRS# 285 - Retired
04 ZX-6R
88 EX500 - Broke
