Results 1 to 13 of 13
Wheel Bearing Help
    To Do That!!!! HanktheTank's Avatar
    Apr 2010
    Wheel Bearing Help
    I am in the process of replacing my wheel bearings on a 2000 SV650 and I have two issues. First, I had no issue punching out both rear bearings using a screwdriver and a mallet (with a little heat). After freezing the bearings, the first side (drive side) went in without a problem so I flipped the wheel over, threw the spacer back in and... it appears to be too long. If I try to put the bearing in, it will contact the spacer before it seats properly. I am wondering if I somehow screwed something up on the install or if the previous owner screwed something up the last time these were replaced, fudged a new spacer and the bearing was never seated the whole way. The length of the spacer is 3.5", if any other SV folks happen to have theirs out, I would appreciate confirming the length. Any other advice is welcome. I can cut the spacer to size but I want to make sure its the right thing to do before I do it.
    The second issue is the spacer in the front wheel doesn't have enough slop for me to get enough bite on the bearings to punch them out. Does anyone have a blind bearing puller in the Boston Metro area that I could borrow... or I could bring the wheel to you if you prefer.
    Thanks!
    Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 5_0_1 like Mac OS X) AppleWebKit/534.46 (KHTML, like Gecko) Version/5.1 Mobile/9A405 Safari/7534.48.3)
    Mike. I can help you out. You aren't supposed to fully seat the bearings. You are supposed to install them to almost touch the inner spacer but not quite.
    Nov 2007
    Re: Wheel Bearing Help
    are you talking about for the SV specifically or in general?
    And I assume you mean the inner lip on the hub, not spacer
    Zip-Tie Alley Racing
    LRRS/CCS #103
    http://motorcycleroadracingforums.co...nread#post8600
    I did them on my gixxer this summer with degsy
    Quote Originally Posted by ceo and a bunch of numbers
    Te bearings sit quite a bit away from the inner lip of the hub and just about 1/16 shy of touching the inner spacer.
    Lifer Stromper's Avatar
    Eastern Ct
    It should be close a few thousandths clearance
    This to assure that the axle nut pressure doesn't squeeze your balls
    The calculus of hate
    Apr 2010
    Thanks for the info guys... this was the first time I had heard that you don't seat them completely into the hub. The service manual didn't mention it at all.
    Quote Originally Posted by HanktheTank View Post
    Factory Suzuki manual?
    Eastern Ct
    If the OD isn't "snug" like just drops in then look for green loctite at bearing houses.
    Balls get support from the housing the race is in
    Apr 2010
    No, one of the aftermarket ones.
    Derek, let me know when you have some free time to help me out with my balls....
    Nov 2007
    Is this specific to suzuki/SV or something?
    The lip is there for the bearing to be pushed to...(?)
    Steering heads, swingarms, wheels... I have always pushed them in until they stop.
    LRRS/CCS #103
    High maintenance priss
    Central MA
    Quote Originally Posted by ceo and a bunch of numbers View Post
    Some bearings are supposed to be set at a specific depth. I specifically remember this called out in the OEM TLR manual for the swingarm.
    Dublin, NH
    On my TLS, the bearings stopped at the spacer which was ever so slightly longer than the edges of the lips.
    2023 KTM 890 Adventure R
  1. Wanted - Parts & Tools | WTB Wheel bearing
    By RC5150 in forum Wanted
    Last Post: 09-22-14, 06:05 PM
  2. 03-06 r1/r6, 05-06 fz6 rear wheel bearing kit
    By hondarider102 in forum For Sale
    Last Post: 12-05-10, 07:48 PM
  3. wheel bearing life
    By Wishbone in forum Bike Maintenance
    Last Post: 06-26-07, 09:20 PM
  4. Death of a Wheel Bearing
    By The Snowman in forum Bike Maintenance
    Last Post: 05-02-07, 07:25 AM
  5. WHeel bearing for TTR
    By ftrain in forum Dirty Bastards
    Last Post: 07-29-05, 06:28 AM
