Results 1 to 7 of 7
Keihin Flatslide jetting? FCR39's on SV650
    Hey folks, anybody here run Keihin FCR39's on a first gen SV650? I have that combination and it came to me without any main jets. I'm looking for a starting point. Stock motor, Hindle pipe, 15/45 gearing and track day use only. Tried the search feature, no luck...
    Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 5_0_1 like Mac OS X) AppleWebKit/534.46 (KHTML, like Gecko) Version/5.1 Mobile/9A405 Safari/7534.48.3)
    Don't have any insight for you but god bless you. Thy are gonna be a bitch to set up but be sweet as honey when you get them running well.
    Roslindale, MA
    Might want to give the guys over at FactoryPro a call.
    Jan 2010
    Farmington, CT
    Re: Keihin Flatslide jetting? FCR39's on SV650
    Pretty sure I was running 162 to 165 Keihin Main Jets on my SV Superbike with hot cams and stock bore pistons & compression with Full M4 Exhaust. Had to revert to bone stock bottom-end after Falicon rod broke on +2mm motor. The key to getting good performance with Flat-Slides is to adjust the spray duration of the accelerator pump (typically about a second is better than too long). Also ran K&N Pod filters that just squeezed together enough to fit under gas tank with proper carb adapters.
    i think the answer is obvious.....just give up. give them to me and ill find something to do with them. ill even give you a set of stock SV carbs
    Quote Originally Posted by wheelieman14 View Post
    Thank you for the starting point. I'll aim around there to begin with.
    I think the answer is obvious.....just give up. Give them to me and I'll find something to do with them. I'll even give you a set of stock SV carbs plus $700 cash
    Deal! Meet me after the first few trackdays, I'll be needing the coin by then.
    KB KB's Avatar
    Manchester NH
    Call Spears he is the SV Godfather!
    LRRS/CCS EX #13
    GMD COMPUTRACK
  1. Replies: 0
    Last Post: 10-24-13, 03:27 PM
  2. Keihin FCR 41mm carbs $775obo
    By Heylewy in forum For Sale
    Last Post: 05-21-13, 08:25 AM
  3. Looking for some Keihin main jets...
    Last Post: 11-24-12, 02:39 AM
  4. Keihin PWK36 carburetor
    By breakdirt916 in forum For Sale
    Last Post: 05-25-11, 03:18 PM
  5. SV650 modding, pro. jetting needed.
    By Qfactor in forum Bike Maintenance
    Last Post: 03-27-06, 03:13 PM
