Results 1 to 4 of 4
Valve job ?
    Junior Member capriccio's Avatar
    Pawtucket, RI
    Valve job ?
    Hi folks. I've got a 09' Ninja 250 that need valve check/adjustment very soon. I want to find a shop or someone reliable to do it. What shop do you guys recommend ? Obviously the cheaper the better.
    I know at my mechanical-handy-man level, if I do it myself, it will take 2 weeks .
    Jul 2008
    Waitsfield, Vermont
    Re: Valve job ?
    It really isn't that bad. The hardest parts are (a) getting a good angle with the feeler gauges and (b) making sure that you tighten the locknuts enough but not too much. It is time-consuming—you have to remove the fairing and tank, unbolt the radiator, and probably a few steps that I've forgotten in order to get the valve cover off—but none of it is particularly hard (IMO). If you haven't read the Ninja 250 FAQ at http://faq.ninja250.org/, take a look. The special Kawasaki tool is really nice to have and not particularly expensive.
    (I learned how to do valve adjustments on my 250, and it was rather intimidating the first time, but it got much easier...and if you put on any serious miles, it makes life much more economical.)
    Oh, and sorry, I have no good recommendations in your area. I just think that doing it yourself is worth consideration.
    Re: Valve job ?
    After you check/adjust yer valves, do a compression test to determine if ya need a valve job or not
    Re: Valve job ?
    08+ ninja 250 are shim under bucket. Ninjette.org had a DIY there.
    I had Razees do my 250. 3 needed to be shimmed out of 8 at 7,500 miles.
    2013 ZX6R-636
  1. M4 / set valve changes
    By gixxer72 in forum General Bike Related
    Last Post: 03-16-16, 05:42 AM
  2. First Valve Adjustment
    By Swizz in forum Bike Maintenance
    Last Post: 03-09-16, 08:41 AM
  3. Tip over valve
    By Golgo13 in forum Bike Maintenance
    Last Post: 05-27-10, 08:43 AM
  4. Valve Adjustment
    By csmutty in forum Bike Maintenance
    Last Post: 12-31-09, 11:32 AM
  5. Need help with valve check
    By ducster in forum Bike Maintenance
    Last Post: 05-08-09, 11:07 AM
