Results 1 to 8 of 8
Broken Rearset
    Lifer Punjistick's Avatar
    Norwell, MA
    Broken Rearset
    Any ideas on how to fix this? I'd like to do it myself in order to save some $$$. I have access to just about any tool and also MIG welder and Oxy/Acet but I havn't used MIG before. Any help would be much appreciated.
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    Broken Rearset
    that kinda looks like aluminum at first glance, you'll need a talented welder to fix that if thats the case.
    Brent LRRS #772
    2006 KTM 560 SMR
    Norwell, MA
    Broken Rearset
    It is aluminum. It's actually the part of the frame that is broken. Here is a better pic.
    Mar 2002
    Amherst, NH
    Broken Rearset
    if it were steel, i would grind those bastards off and fab up some new stronger bracket with the threaded eyelets/holes in the right place and weld the whole new braket right on and bolt up the rear set.
    not sure if its that simple in aluminum, different metals need different things. you need someone that is more knowledgable in that metal.
    Brent LRRS #772
    2006 KTM 560 SMR
    Senior Member MsHap's Avatar
    Broken Rearset
    I had that happen on my FZR. Well I got it that way.
    I built it up with MIG and then redrilled and tapped.
    It was only the bottom one and I ended up going with 6mm instead of the 8mm.
    That is going to be tough Sorry
    You could add a plate behind the frame and then some spacers to bring it back out that far. Kind of what Oreo_n2 was talking about?
    My Name is Chrissy
    This is Jello
    Have you hugged a corner today?
    Feb 2004
    Bellingham, MA
    Broken Rearset
    Give me a call, I fix those all the time.
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    Broken Rearset
    When you get it welded up...CLEAN THAT CHAIN! LOL
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Broken Rearset
    I've got a friend up my way that can weld ANYTHING. Not sure if it'd be worth the haul for ya. But he'd probably do it for a big jug o' Jack...
  1. 2nd Gen SV rearset position
    By NPDCPA in forum General Bike Related
    Last Post: 07-17-13, 08:39 AM
  2. 04 / 05 GSXR Rearset
    By RacerXnh10 in forum Wanted
    Last Post: 05-04-13, 12:48 PM
  3. Where to get rearset bolt and pin?
    By virtualbong in forum General Bike Related
    Last Post: 07-19-11, 02:39 PM
  4. rearset alternative??
    Last Post: 03-16-07, 02:11 AM
  5. Rearset.
    By BigShel in forum General Bike Related
    Last Post: 11-02-05, 05:22 PM
