Results 1 to 10 of 10
Using a front stand
    Using a front stand
    Finally got the nerve to lift the front of my CBR off the ground with no one else around to help. Dry run before putting on new tires for the 10/17 track day. Put the bike on the rear stand. Put the bike up on the front stand and realized axle probably won't slide past the side of the stand. Took it off the front stand, wrapped a rag around the lower peg of the front stand, and lifted it again. Now have a couple mm clearance to slide the axle by the side plate. Anyone have a better way to do this? I tried lifting the front wheel a couple times to get more clearance, but no luck without putting the rag to get more clearance. Thanks.
    2013 ZX6R-636
    AM #152 tropicoz's Avatar
    Apr 2010
    Maine
    Re: Using a front stand
    Grab a dremel or die grinder and clearance the brackets on the stand.
    Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 4_2_1 like Mac OS X; en-us) AppleWebKit/533.17.9 (KHTML, like Gecko) Version/5.0.2 Mobile/8C148 Safari/6533.18.5)
    Buy a real front stand. Hate to put it like that but you need a better front stand. You get what you pay for with stands.
    Lifer BostonSVkid's Avatar
    Dec 2005
    +1 get a front stand that is a pin style that holds it from under the triple trees.
    2006 Ducati Monster S2R800
    Oct 2008
    Albany, ny
    Get creative , get some hardened bolts, grind them to a soft point , and weld them on.
    Beat It Like A Rented Mule !!
    Legend in my own mind
    #331 CBR929RE's Avatar
    Bridgewater, MA
    would flipping the silver pieces to the other side help?
    Member timv2444's Avatar
    May 2010
    Shirley,MA
    Woodcraft front stands work awesome.
    No offense taken, Harbor Freight cheapie, just hoping to lift bike long enough to go get tires mounted.
    It might, wasn't sure if they "balance" better in the current position.
    Quote Originally Posted by tropicoz View Post
    Might be able to grind enough of the plate off.
    Quote Originally Posted by BluGixxer View Post
    And then come up throught the hole under each fork leg?
    Quote Originally Posted by timv2444 View Post
    Will keep that in mind.
    Dealer is trucking the bikes to the track day this weekend, when I drop it off to them I'll probably have them do the whole tire swap, but wouldn't mind doing some of the job myself to save some money. Thanks all.
    2013 ZX6R-636
    Oct 2008
    Albany, ny
    Forget the bolt and weld idea.
    I think your best bet is to do the die grinder/dremmel tool to remove enough material to slide out the axel shaft.
    Apr 2008
    Boston, MA
    Ladder + ratcheting tie downs
  1. For Sale - Other | FS: Pit Bull Front Triple Stand $125 & Forward Handle Rear Stand $100
    By kumpy in forum For Sale
    Last Post: 06-11-14, 05:44 AM
  2. For Sale - Parts & Tools | Pitbull front stand and vortex rear stand and chinese knock off
    By black in forum For Sale
    Last Post: 04-17-14, 09:50 AM
  3. Replies: 14
    Last Post: 02-27-13, 08:00 AM
  4. Replies: 11
    Last Post: 07-09-12, 05:03 PM
  5. WANTED: rear stand (non-spooled), and front fork stand
    By Pleasegivesoap in forum For Sale
    Last Post: 12-14-08, 10:42 PM
