Results 1 to 20 of 20
need cable made
    need cable made
    it's a Y-adapter for my ECU (not factory).
    i'm struggling to find the black plug online.
    anyone got leads, or have the ability to make one of these suckers?
    need cable made-cid_ec763273-d332-49bd-b2fe-589ded66828a need cable made-yosh-adapter-pdf
    Re: need cable made
    for an OEM wiring harness on an 06 GSX-R 600
    Apr 2011
    NH
    Re: need cable made
    argos?
    oem plugs can be hard to find, as I'm sure you figured out. The best may be a scrap harness. Is there one on your old bike?
    Tim
    LRRS #44
    Superbike Services 44
    TWINS! xrocket21's Avatar
    Central Maine
    Re: need cable made
    Hey man, if you can source the part, Id be happy to solder it up for you.
    Re: need cable made
    Don't need to solder. I've even got the pins for the plugs already.
    The plugs are the issue I'm having. I have one from my old wire harness.
    The other two are what I'm struggling with.
    Wirelessly posted
    If you have a complete old wiring harness, you must have all the plugs you need, right?
    Wanker 2v2Ducati's Avatar
    Medford, MA
    Re: need cable made
    IF you have a pair of calipers and time just use digikey or mouser, go to automotive connectors and use search options to cut down the options then view the data sheets till you find a match.
    Like I said they say, nothing stops a party barge.
    97' Ducati 900SS - Sometimes runs
    Re: need cable made
    Jim I have a site you can get the plugs from when I was looking for the injector plug
    Re: need cable made
    Just buy a couple of waterproof wiring connectors and replace the stock ones.
    Something like this. http://www.amazon.com/ACCEL-74812-We.../dp/B001HQEUKC
    Did this on my Aprilia to replace a burnt out stock connector.
    Jan 2012
    Lowell
    Re: need cable made
    This... Or just make the connector a wire to wire connection (solder and heatshrink), I'm good at that if you need someone to do it.
    Re: need cable made
    It's for an adapter to plug my tuning cable into the ECU plug. I'm not cutting OEM connectors to solder in a tuning cable adapter.
    If I can't find the source for the proper plugs, then I'm just going to rig something up to jam some copper in there while I'm tuning the ECU.
    Jan 2012
    Lowell
    Re: need cable made
    Is this the 8 pin?
    http://www.corsa-technic.com/item.ph...category_id=95
    Heres the 6 pin page, any of these line up?
    http://www.corsa-technic.com/categor...category_id=59
    If you get the stuff (or just have me order it and get back to me in September) I can get the cables together for you no problem (what I do for work)
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Re: need cable made
    if any of these suggestions doesn't pan out try calling Bazzaz and asking them if they have a connector or can tell you where they get theirs
    Re: need cable made
    i got a lead on one.
    the guy on WERA that sent me the pictures actually had spare cable and plugs. he's shipping me out one today.
    thanks everyone for your terrible suggestions
    Re: need cable made
    Our terrible suggestions are easily explained by your terrible description of what the hell it is you were trying to do.
    Re: need cable made
    I could had this cable YRS ago.....SUKKA
    Life is good! gadget's Avatar
    Nov 2008
    Londonderry
    Re: need cable made
    so basically you posted asking for help, did it yourself and then insulted the guys that offered solutions...
    You Sir, epitomize the true spirit of a Nesrian...now
    Sam
    Re: need cable made
    i stand corrected....only Pete's goatee gave me the terrible suggestion
    the links you guys put up were actually helpful, but i'd never admit that to you assholes
  1. Anyone have a PCII cable?
    Last Post: 09-17-09, 01:28 PM
  2. clutch cable
    By neuthunder in forum Bike Maintenance
    Last Post: 07-25-05, 05:50 PM
