Results 1 to 10 of 10
Caliper issues
    Mar 2004
    Rochester Wa
    Caliper issues
    Hey,
    Put some Galfer wave rotors on my old cbr900 along with braided lines. "front end" The calipers are not opening wide enough to allow the wheel to spin. I have them bled out well enough. My next thought was to rebuild the calipers. Anyone have any ideas or directions to go? thanks
    Lifer Stromper's Avatar
    Eastern Ct
    Re: Caliper issues
    1 st make sure they are the same thickness and maybe off set as stock
    2nd Look to see if you screwed up and the are not mounted at a cant and or buttons not moving if you have buttons clean and free them
    3rd sizable air still in system sometimes act as a spring pushing the piston back out. Bleed bleed also at banjos
    4th Older calipers can/will get some corrosion behind the normal position of the pistons
    this stops them from moving freely or sometimes even having you push them back. Small amounts of corrosion can be removed and polished but big pits and your screwed. Lastly the retraction of the piston is only by the O ring elastic rolling back which is a small force at best. IF you have new rubber it is stronger
    Re: Caliper issues
    i've done this on both my bikes this year, so i could offer some tips if needed. i've written up a thread about what steps i used, but this should work....
    get a seal kit from your local dealer. they cost about $50.
    open the calipers up in half by removing the pinch bolts, and keep everything organized (right, left, inside, outside).
    leave the bleeder & banjo in the caliper. with compressed air, shove the air nozzle down the small hole inside for the fluid. make sure to aim the caliper pistons ina trash barrel, as they shoot out rather quickly. one the 1st piston is out. carefully place the 1st one slightly back in & put a c-clamp over it. then use the air nozzle to fire out the other piston.
    clean the pistons and calipers with brake cleaner & use air to dry everything out. after inspecting the pistons for any scarring or damage, install the new seals in the calipers. make sure to use some brake fluid to lubricate the new seals. then install the pistons back in.
    put the caliper halves back together using the pinch bolts.
    bleed the system out for the rest of your life.
    Mar 2004
    Rochester Wa
    Re: Caliper issues
    Thanks you guys. I'll give it a shot.
    Re: Caliper issues
    When cleaning the calipers, use a dental pick and really make sure the corners of the seal grooves are clean. That's where crap builds up, and it doesn't take much to cause the seals to 'jam' a bit against the pistons, preventing them from retracting properly.
    Mar 2004
    Rochester Wa
    Re: Caliper issues
    Thanks a lot.
    Oct 2008
    Albany, ny
    Re: Caliper issues
    When reassymblying the calipers what type of grease or lube do you sugest, I know some products make rubber swell over time.
    Silicone grease,
    Anti-sieze
    Caliper slide grease
    A little brake fliud,
    Or dry ?
    Sugestions ? Thanks
    I'm going tru the same thing soon.
    Beat It Like A Rented Mule !!
    Legend in my own mind
    Re: Caliper issues
    Brake fluid only, don't want anything in there that can contaminate the brake fluid.
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Re: Caliper issues
    Honda Service Manual for my 929 says to use Silicone grease on the dust seals (seals closest to the pads) and brake fluid on the piston seals (ones further inside the caliper)
    Uxbridge, MA
    Re: Caliper issues
    That's how I did them on the R6 when I rebuilt them.
  1. R6 caliper rebuild
    By Dip Dungles in forum Bike Maintenance
    Last Post: 02-19-13, 07:14 PM
  2. reinstalling a caliper
    By breakdirt916 in forum Bike Maintenance
    Last Post: 05-17-10, 10:36 PM
  3. wtb \\\\\ BRAKE CALIPER /////
    By Bandit12k in forum Wanted
    Last Post: 03-07-10, 11:24 PM
  4. WTB 6 pot brake caliper
    By Bandit12k in forum For Sale
    Last Post: 12-07-09, 10:17 PM
  5. WTB 94+ EX500 front caliper
    By Pittenger5 in forum For Sale
    Last Post: 06-26-08, 11:23 AM
