Results 1 to 25 of 28
Calling Carburetor masters
    60% squid duganc1717's Avatar
    Dec 2008
    Framingham
    Just got an 97' GSXR 1100 and the bike has been sitting for awhile.
    It's running on three cylinders w/the fourth cutting in and out on high idle (choke on). I know the fuel needs to dumped and the Petcock screen cleaned.
    What are the main areas to be concerned with and cleaned?
    Main jet and Pilot Jet?
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Re: Calling Carburetor masters
    float and needle, especially if it's a float that slides rather than pivots
    Member gixerhp's Avatar
    Jun 2009
    Nashua
    If it has any Ethanaol gas in it, the pilots will need to be cleaned!
    Performance: 1397 JE bigbore, Dual Intake cams, Adjustable cam spockets, Sm air box mod,Pc3 usb,Ingnition box w/hub, and Lcd screen, Hindle stepped race header, Dual Fans, 24 volt starting
    Suspension & Brakes: Ohlins road and track forks, Ohlins rear shock, Sprint top mount dampner, PRM top clamp, Dymag Carbon mags, Brembo HP rotors, Brembo Hp radial calipers,
    Show & GO: Topgun undertail, Libertek led lights, Pazzo lever, PMR Switches & Kill,PMR cover. Revolution Custom Paint, Harris Grips.
    Waterbury, VT
    You'll also want to take a look at the boots from the front of the carbs to the intake. If they're dry rotted or cracked. Any ports machined into the bodies have to be cleaned as well. When you have the carbs off - do one at a time... Sometimes the inner carbs have different jets in them than the outer carbs.
    SSearchVT
    Save yourself the trouble, pull the carb bank and do a complete teardown, soak in cleaner then blow compressed air into every chamber and orifice.
    There could be blockages within the casting itself.
    Roslindale, MA
    Seafoam is your friend as far as preventative measures go once you get them cleaned. That way you won't be beating your head against the wall with ethanol flavored Jell-o.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Not just compressed air, but aerosol carb cleaner, you can't see air, but you are assured when you can see the carb cleaner come through. Also run a wire through the jets as well don't trust air or cleaner to get them 100% clean.
    Posted by Jane in BoxChat
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Also spark plug boots and wires
    Glen Beck is John the Baptist
    Dec 2008
    Framingham
    The header pipe furthest to the left was cool when I started it. So I would assume that is the cylinder not firing.
    I pulled the carbs, all the bowls have gas in them and only one had very minimal sediment/debris.
    Removed the main jets and pilot jets and none appear clogged. I can see through all and blow through all of them?
    I probably pull the plugs tomorrow.
    talk to the Mr Wizard of carbs (TLRman)
    Westford, Ma
    Quote Originally Posted by duganc1717 View Post
    not to be a dick or repetative..
    Quote Originally Posted by bergs
    there is more than a main jet and a pilot jet. Did you take the whole carb apart? pull the needles? the tube the main jet sits in? Did you run a wire through the circuits the jets are in?
    Dec 2008
    Framingham
    Quick update, I soaked the main and pilot jets and blew air through the circuits. And cleaned the bowls, I did not run a wire through anything.
    Reassembled @ 11:00pm last night and the number 1 cylinder header pipe is still cool when running. This morning I swapped the number 1 cylinder spark plug w/number 4 cylinder spark plug and guess what.
    Number 1 cylinder header pipe is now hot and number 4 is cool. I'll change all 4 plugs shortly.
    Anyone know where I can buy Seafoam local to Framingham? The gas tank has some debris I like to flush out.
    Westford, Ma
    Doesn't sound like plugs but maybe the coil. Check the plug wire ends as well.
    what about that harley dealer on rt 135 in framingham? they might sell it
    Dec 2008
    Framingham
    Quote Originally Posted by DBKromz View Post
    There is no need to be mean about it.
    Lifer Pittenger5's Avatar
    Austin
    Have you checked the brakes?
    Zip Tie Alley #505
    Nov 2007
    Autozone on route 9 by the scrubadub
    Zip-Tie Alley Racing
    LRRS/CCS #103
    it was an honest suggest they sell carb bikes, so i'm sure they sell carb treatments. but now that chris mentioned it, Autozone should have it too.
    seafoam can be found at autozone, pep boys, advance auto, walmart
    Aug 2004
    Baltic,CT
    Go online find some Iridium Wire electrode plugs
    Put in and forget
    Dec 2008
    Framingham
    I put the new plugs in and drained the tank again. Put fresh gas and Seafoam in and what do you know I have all 4 cylinders firing!
    Took for a ride on rte 9 to 495S and a few miles before Hopkinton I started losing power, by the time I got to the breakdown lane it died.
    I tried to start for a few minutes and it would sputter and then die It would start w/the choke on, but opening the throttle @ all would kill it.
    So while I was deciding who to call for a ride, I popped the gas cap and tried on more time. ItfFired and one by one each cylinder kicked in. The only thing I can think of is the vent for the tank was plugged.
    Rode home and blew out the vent hose on top of the tank and the fitting going into the tank. Rode it about another 80 miles and it was fine. Carbs definitely still need some help, but it runs and drives.
    Pulls like a freight train and first gear is useless except for spinning the tire.
    The bike is unbelievably clean original w/10k miles from the original owner.
    Dec 2008
    Framingham
    Jim, I didn't realize you are the sensitive type!
    hey, how about you stop buying POS bikes and get something newer with fuel injection
    Derry NH
    You should have sprayed everything down with carb cleaner instead of just spraying air through the passages. All you gotta do is take the bowls off and floats off, and spray though every hole you can find until the can's empty.
    Aug 2004
    Baltic,CT
    next balance the carbs
  1. Where do these go on my carburetor?
    By Gman021 in forum Bike Maintenance
    Last Post: 05-12-15, 01:30 PM
  2. Carburetor virgin
    By oVTo in forum Bike Maintenance
    Last Post: 11-18-12, 07:12 PM
  3. Keihin PWK36 carburetor
    By breakdirt916 in forum For Sale
    Last Post: 05-25-11, 03:18 PM
  4. Mikuni TMX carburetor, from 03 Yamaha YZ125
    Last Post: 02-28-10, 09:10 PM
