Results 1 to 4 of 4
Car headlight help
    Lifer Pittenger5's Avatar
    Austin
    Car headlight help
    Trying to help a wifes friend, she has an older BMW 7series that has an HID conversion done to it. One headlight doesnt work, she says if the car sits overnight or something and she turns them on it works, if she drives at all then turns it on it flickers and then shuts off. I checked the wiring quick, and it looks clean and secure. Any other suggestions?
    Zip Tie Alley #505
    Lifer NobodySpecific's Avatar
    Apr 2008
    Burlington, VT
    Re: Car headlight help
    Wild guess: could the ballast be failing at the higher voltages (versus turning on with a somewhat stable and/or lower voltage either before or while starting)? Or the ballast could be overheated by the engine and fail to turn on. Turning on is the hardest time for the ballast since that is when it generates a high enough voltage to get the gas to generate light, which is significantly higher than the voltage required to maintain the light.
    '06 Triumph Sprint ST ABS
    '90 Yamaha XT350
    Nov 2009
    Bristol County
    Sounds like a bad ballast. Swap it to the other side, see if the problem "follows" it. If it does, replace it.
    nedirtriders.com
    Lifer golden chicken's Avatar
    Attleboro, MA
    ^^or swap the bulbs around.
  1. Wanted - Parts & Tools | WTB SV Headlight
    By Petorius in forum Wanted
    Last Post: 06-07-17, 08:56 AM
  2. Replies: 2
    Last Post: 10-12-16, 04:08 PM
  3. '02 F4i headlight
    By Kazinator in forum Wanted
    Last Post: 08-06-11, 03:31 PM
  4. 03 R1 headlight
    By chr|s sedition in forum General Bike Related
    Last Post: 06-17-05, 06:07 PM
  5. Headlight Nonsense
    By benVFR in forum Bike Maintenance
    Last Post: 05-03-02, 12:58 PM
