Dll'ortos? What year 900SS do you have?
If its a 1995 900SS, and its using the stock carbs, their Mikuni CV's.
just put your whole carb assembly complete in a bucket of highly corrosive acid solvent for 3 days--no more--then immediately remove them, soak in a warm water soapy solution for 2 hrs, then rinse with cold water only + leave out in the sun to fully dry for 1-2 days. your problem will be solved!!!
Doc, try the same thing!!
There were motors using POINTS manufactured during this decade? That's incredible to me, I was under the impression that everything had converted by about 25-30 years ago -- I figured that mass produced CDI systems must have been cheaper (as well as better) by now.
Amazing, you learn something new every day.![]()
Joe
04 Thruxton (Street)
01 SV650 (Track)
