Results 1 to 10 of 10
Cartridge fork revalve
    Question Cartridge fork revalve
    Anybody out there ever re-valved a Showa upsidedown fork before? Specifically the rebound? I'm having trouble getting the valve out of the cartridge...
    So far I have: drilled out the dimples and removed the "cap" of the cartridge; removed the circlip holding the top out spring
    I can see another circlip, but access is impossible. Is there a way to push the valve out the bottom???
    OK, if it goes out the bottom, then there is a collar that is peened on the rod that must be somehow released. I don't know how to do this. Any ideas?
    Angry Man Racing Collision pro's Avatar
    Jan 2003
    NC
    If I was you I would give them to kmf and let him do them. I would not feel safe trying to remember if I put them back together right. Never mind to fact that you have to know alot about the valves and shim stacks to get them to work good. He knows that well and has built some awesome forks.
    Collision Pros Racing
    Jan 2003
    NC
    Originally posted by kmf
    Well it is amazing what you can do with $3k worth of Ohlins internals.
    I still can't believe the deal I got on them!
    Jan 2003
    NC
    Well that would be the second time that a set of forks that had "$3k worth of Ohlins internals" were sold for $600.
    They were cheaper them that!
    Yes, I read it. The rod will not push the piston out the bottom because there is a collar that stops it at the top out spring. I'm definitely in over my head here, and no one seems to know the set-up on this fork. It's a 35mm upsidedown showa from a 95 RS125.
    Where are you located? What would you charge me to finish this job?
    Jan 2003
    NC
    I am in Walpole, right up the street from Gillette Stadium.
    When you ask me how much would I want to finish them, what exactly are you doing?
    I am screwing them up and I just can't figure out how to get them back together. J/k
    Custom User Text zx7rou812's Avatar
    Mar 2004
    Stoughton, Mattachusetts
    Mike, did you screw them up or did your helper Captain Morgan screw them up for you?
    "Arg, Matey...T'was that rat-bastard Captain, it T'was"
    You rebuild rear shocks as well KMF ? Fox Twin Clicker to be precise.
    Signature:
    Optional signature you may use to appear at bottom of your posts.
    HTML code is ON
    vB Code is ON
    [img] code is ON
    Smilies are ON
    Jan 2003
    NC
    Kevin can do anything.........He's a god in my book!!
    Captain speaking now!!
    Mar 2004
    I have rebuilt some stock dirtbike shocks.
    Some of the aftermarket shocks require a fair amout of specialty tools and I do not have enough of a calling for shock work to justify the expense of the tools.
    If you need the shock serviced I would recommend Traxxion Dynamics.
    OK, thanx meng. I'll just send to Fox
    Signature:
    HTML code is ON
    vB Code is ON
    [img] code is ON
    Smilies are ON
  1. For free: Cartridge Oil Filter KN-152
    By keeena in forum One Man's Garbage...
    Last Post: 05-21-19, 01:14 PM
  2. For Sale - Parts & Tools | 2006 Yamaha R6 Front Suspension W/ GMD revalve
    By Brendin87 in forum For Sale
    Last Post: 12-20-14, 02:49 AM
  3. Fork cartridge, emulators, and pistons?
    By kumpy in forum Bike Maintenance
    Last Post: 03-29-13, 11:22 AM
  4. Marzocchi cartridge cap not reaching specified torque
    By kbroderick in forum Bike Maintenance
    Last Post: 07-03-12, 04:26 PM
  5. Revalve
    By minutiesabotage in forum General Bike Related
    Last Post: 08-19-08, 08:43 AM
