Results 1 to 8 of 8
Brake Pad change time...
    Custom User Text zx7rou812's Avatar
    Mar 2004
    Stoughton, Mattachusetts
    Recommended/preferred manufacturer and compound. Won't see the track, I think...So we'll stick to street compound suggestions...
    Pads are going on a 98 ZX-7R, 6 piston, OEM Tokico calipers
    Signature:
    Optional signature you may use to appear at bottom of your posts.
    HTML code is ON
    vB Code is ON
    [img] code is ON
    Smilies are ON
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    You'll be happy with EBC HH. I still think the stock pads for that bike are the best....but the HH's are a nice compromise and less expensive than what Kawi will ask.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    are they reasonably priced, Kevin? I'm running the HH's on my ZX? with Brembo rotors, but quite a few folks have been trying to get me to switch the combination.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Lifer GMAN226's Avatar
    Coventry RI
    The PF's are great.. I think that the set was less than $70. I used them all last year and they are still in great shape
    G-man
    Gerard
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    I'm sitting on a brand new set of Ferodo's, so I may just use them. The HH's are running thin and I really can't justify the price if Im not racing. I think those rotors will work well with other italians...lol.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Coventry RI
    If you aren't racing you shouldn't notice much of a difference. The biggest difference between pads is if they have good initial bite or they stay the same all the time(no fade). On the street you are off the brakes enough that you will get consistant performance out of most brands and compounds. Once you get used to what you put in you will like them. That is what I have found. Just my $.02
    G-man
    Gerard
    Mar 2004
    G-man
    Sounds good to me
    Thanx meng
    Signature:
    HTML code is ON
    vB Code is ON
    [img] code is ON
    Smilies are ON
    Mar 2004
    Hmmmm...Ok, clearer now !
    Signature:
    HTML code is ON
    vB Code is ON
    [img] code is ON
    Smilies are ON
  1. Quick change front brake calipers.....MotoGp!
    By Tricklidz in forum General Bike Related
    Last Post: 11-07-15, 10:36 PM
  2. Replies: 0
    Last Post: 02-27-12, 10:34 AM
  3. Time for a change?
    Last Post: 09-14-10, 11:40 AM
  4. time to change air
    Last Post: 09-27-07, 09:58 AM
