Results 1 to 25 of 37
Helicoil?
    Lifer akira700's Avatar
    Apr 2005
    in the city
    Helicoil?
    So where around Boston does one buy Helicoil stuff?
    Need to repair a stripped bolt hole.
    Just got off the phone with Sears and the guy in tools was like...
    Whaaa?
    2008 Honda CBR 600RR
    Lifer JohnnyV's Avatar
    Westborough, MA
    Re: Helicoil?
    I know most bike shops can DO the helicoil repair, perhaps they would sell you the materials to do it yourself?
    Apr 2005
    in the city
    Re: Helicoil?
    duh, Auto Zone has it.
    Thanks...
    Usually its the other way around though...
    You get the dumb blank look from the Auto Zone folks
    and Sears is on the ball.
    Lifer Pittenger5's Avatar
    Austin
    Wirelessly posted (BlackBerry9530/4.7.0.148 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
    Metric tool and supply in wakefield. I just bought one last week
    Zip Tie Alley #505
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Re: Helicoil?
    Always www.mcmaster.com delivered tomorrow ground
    Glen Beck is John the Baptist
    Dublin, NH
    Re: Helicoil?
    Is it something you can just tap with a tap and die set?
    2023 KTM 890 Adventure R
    Apr 2005
    in the city
    Re: Helicoil?
    Yeah, I'd prefer to keep the stock bolt. I'd hate to have a find a bigger bolt
    that fits as its countersunk flush with my gap cap mount.
    Dublin, NH
    Re: Helicoil?
    Is the thread actually stripped out or just jammed with rust/metal/etc?
    Oct 2007
    Peabody Assachusetts
    Re: Helicoil?
    yes, a lot of times you can just chase the thread with the same thread tap. Now what are you up to??
    Apr 2005
    in the city
    Re: Helicoil?
    No the threads came right out like a Heli-Coil !
    Don't think I can retap it in the same dimension.
    Oct 2007
    Re: Helicoil?
    then you need a helicoil drill/tap and the insert itself. Make sure you get the tool to install it too. Usually comes in a whole kit.
    Break the tang off after installing too.
    Dont use that loctite shit either!
    who knows
    Re: Helicoil?
    use a Time-sert instead... much better than a Helicoil. It's cased hardened and they are approved for aircraft repairs which i'd trust better.
    Nov 2007
    Re: Helicoil?
    Quote Originally Posted by brendanp View Post
    I have red loctited helicoils in place... why are you saying not to?
    And be careful breaking the tang off... don't let it end up in an engine or gas tank.
    Time serts are better but not always an option because they have a lip/flange that sits on top of the mounting surface.
    If you're doing this in a sealing/gasket surface or other situation where you need the surface to be flush afterwards they don't work. For example, a case cover bolt.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    who knows
    Re: Helicoil?
    Quote Originally Posted by ceo and a bunch of numbers View Post
    If done properly the Time-sert does sit flush... (meaning you need to use the seatcutter)
    A video from the company that makes it... Take a look at first 2 mins and you'll see what i mean.
    Also look at the the video at 3:14... another reason why Time-Serts are better that Helicoils (they lock in place and there is no nipple to tap out and maybe get stuck somewhere.)
    Oct 2007
    Re: Helicoil?
    It was a joke from his other thread! But you dont need loctite to install a helicoil anyway. And I agree with you about if you need it to be flush.
    Nov 2007
    Re: Helicoil?
    I can't open that link but I guess you're saying you need to countersink the head of the timesert? I guess that woould work as long as you have enough material... seems like a lot of work though?
    Ahh I gotcha. Yeah I just used it to be sure, can't hurt... also because it was in a location expected to see lots of temperature fluctuations...
    LRRS/CCS #103
    who knows
    Re: Helicoil?
    You should also view the video...
    They use these in airplane engines, thats what I want for my motorbike...
    who knows
    Re: Helicoil?
    I guess that would work as long as you have enough material
    this is true! you need enough material
    only takes the guy 30 seconds in the video and the countersink comes with the kit. It's the strength factor with the Time-sert for me.
    Nov 2007
    Re: Helicoil?
    In one case where I did a helicoil the metal wasnt that thick so the extra loss of material due to to the countersink would have been negated any benefit of the timesert IMO
    Like I said can't see the video at work... does sound like a superior in the right application though
    LRRS/CCS #103
    Apr 2005
    in the city
    Re: Helicoil?
    About it needing to be case hardened etc.
    This is just one of the 9 or so bolts that hold down the gas tank cap assembly.
    In someways I think those bolts are mostly a cosmetic look.
    They are not torqued very hard and its all into aluminum anyway.
    I'd look a alternatives if it was in a strength critical location but
    this one seems not.
    In fact I'm riding the bike now without the bolt! If its spews gas and blows up
    then you write my obituary with all the details!
    who knows
    Re: Helicoil?
    Quote Originally Posted by akira700 View Post
    this one seems not.
    Yea i wasn't sure if it was a application were you needed the stregth or not. You are correct about the tank cap cover bolts. only 3 of them hold the tank cover on. the rest are just cosmetic. the real bolts are at 12 o'clock and 4:30 and 7:30.
    Lifer obsolete's Avatar
    Norf Sho
    Re: Helicoil?
    This bolt holds the gas cap assembly down? Then is it not into the tank and there for steel? Am I missing something?
    -Alex
    who knows
    Re: Helicoil?
    On the CBR's the tank cover has like 10 bolts and the top and two bottom corners are into the tank to attach the cover. the rest are just cometic and stop in the cover which is Aluminum. I'm assuming it is one of these that got stripped. But if it is one of the major 3 ones they do screw into the steel tank.
    Dec 2003
    Ma
    Re: Helicoil?
    You need a 1000.
    Norf Sho
    Re: Helicoil?
    Fuck it and glue it in there.
    -Alex
  1. need to borrow Helicoil tools
    By Jim in forum Bike Maintenance
    Last Post: 12-16-14, 01:40 PM
