Link style o-ring.
I disagree. O-rings slow you down. But since I've only got a 650, I can tell you with confidence I use an EK MVXZ 520. It is a quality chain for reasonable money.
Actually, dyno time shows o-ring chains, while measurably heavier have less friction losses than non o-ring putting more power to the ground.
Spend more than $12 on a 520 'blah'-ring of some type chain. Clean it with WD40 frequently, lube it if you desire, watch the slack and replace when it starts needing frequent adjustments.
DID ERV3. If you want the best.
DID 520 ERV3 chain. That's all you ever get. It comes with a rivet master link.
Don't clean it with WD40....ever.
Use kerosene or a chain cleaning product.
Install the chain around the middle of the adjustment blocks, so you can go up/down sprockets for different gearing at different tracks.
2004 SV650
1979 GS 850GN
2005 Tt-r125
For the record, when I suggest cleaning the chain with WD40, I don't mean taking the chain off and soaking it over night. A rag loaded with a little WD40 used to wipe down the chain should be plenty and won't harm the o-rings at all. For anything more serious I have a steam cleaner that works right on the bike.
If anybody should need a rivet master link for DID ERV3 in a 520 size for FREE, I have 3 extra. Alas, I have no DID ERV3 chain, because she is 'spensive!
Hi,
I wouldn't mind having a spare just in case. I'll be at the classic or however you'd like me to get it.
2004 SV650
1979 GS 850GN
2005 Tt-r125
That would be the most efficacious form of conveyance. Come find me, Center garage 15 #613 Doug Cooke.
Will do, Thanks Doug!
Todd
2004 SV650
1979 GS 850GN
2005 Tt-r125
