Results 1 to 12 of 12
Chain master
    Lifer Pittenger5's Avatar
    Austin
    Chain master
    So I bought a new chain for the racebike (RMZ450) and it comes with a clip style master. Is this enough for racing, or is it possible to buy a rivet type master and use that instead. Basically, what should I do.
    Zip Tie Alley #505
    Worcester, MA
    Re: Chain master
    If you are going to run the clip type, I'd suggest safety wiring it, just loop the wire around the posts. But if you want the rivet type, you should be able to order one easy enough. what kind of chain is it?
    LRRS EX #165 (formerly)
    Austin
    Re: Chain master
    Quote Originally Posted by BMFR6 View Post
    EK 520 MRDL6 non-O ring gold.
    Zip Tie Alley #505
    JACKASS hammadown's Avatar
    Hopkinton, MA
    Re: Chain master
    Call some local dealerships, as they may have the right one in stock. If not contact RK directly. I've had some helpful customer service from them. I've had clips fall off at even slow dirt paces...would want one for road racing.
    Zip Tie Alley #237
    Meriden, Ct
    Re: Chain master
    Local dealer should have it...
    Worcester, MA
    Re: Chain master
    yeah, call your local dealer and get the rivet type. while saftey wiring the clip type can work in a pinch, it's not the best method.
    Re: Chain master
    I don't, I've lost 1 master clip ever in all my years of offroad riding and it was my fault for sure seeing I reused the same clip probably a dozen times. A properly installed clip is not going to fall off and IMO, the clip is a one time use.
    Re: Chain master
    Clip it, then smear with RTV.
    Member madkaw's Avatar
    Nov 2006
    Pittston, PA
    Re: Chain master
    What's RTV? And what will that accomplish? Just wondering becuz I have a clip style masterlink. I was in a pinch and desperately needed one. That's all the dealer had available.
    Re: Chain master
    Silicone rubber gasket material basically. If I recall correctly, RTV in this case stands for 'Room Temperature Vulcanizing'. Smearing it on the clip 'glues' it in place, but will allow you to remove it later if needed.
    Registered Snoozer knarlydog's Avatar
    Re: Chain master
    Hey Man, just a heads up, keep a close eye on chain stretch with that model EK chain. I ran one last year on my RS250 at Barber and basically got the weekend out of it. My own fault, I should have spent the extra on the GP 520RX. BTW - I don't think they had a rivet style master for that chain, but if you want some extra clip masters, I've got a couple you can have gratis.
    The Older I Get,
    The Faster I Was...
    Austin
    Re: Chain master
    Quote Originally Posted by knarlydog View Post
    This is what I was told to use by a fast guy, who was told by an even faster guy, so Ill take their word for it, but I will keep an eye on it, thanks.
    Zip Tie Alley #505
  1. wtb master cylinder
    By hondarider102 in forum Wanted
    Last Post: 05-23-11, 10:25 AM
  2. Replies: 0
    Last Post: 05-03-07, 12:51 PM
  3. Any difference between bicycle chain wax & motorcycle chain wax?
    Last Post: 06-29-04, 12:23 AM
  4. Best chain lube , and adjusting chain ?
    Last Post: 05-28-03, 09:17 PM
