Results 1 to 12 of 12
Chain question
    Woooooosta
    Chain question
    This might sound like a stupid question but i just finished putting my chain on Thursday. Got it nice and hot this morning and lubed it up. The question is when its on the rain stand the chain isnt smooth it almost moves a little bit side to side, maybe like 1mm if that. Now i know the old chain did that but i wasn't sure if the new one was supposed to do it as well and if its normal.
    Lifer FirstDuc-1098's Avatar
    Central Mass
    Re: Chain question
    did you replace the sprockets along with the chain? You should have. If it is the old sprockets then you are probably seeing the wear of them. And they will also destroy the chain
    Woooooosta
    Re: Chain question
    Sorry i should have clarified, i did replace the sprockets with Sunstar steel sprockets drive and driven sprockets. I also have the chain slack at 1in right now like in the manual for the f4i. It almost makes like a burring sound, i'm pretty sure its fine when riding around but idk if its normal or not. Hopefully its nothing major, i did nothing the front sprocket move a tiny bit when i put it on but the old one did the same thing. Once it was torqued down and the chain on it didnt move at all so.
    Wirelessly posted (BlackBerry8330/4.5.0.160 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
    No issues. Sounds all normal.
    Lifer Currently's Avatar
    Ooltewah, TN
    Re: Chain question
    +1
    Keep it cleaned and lubed every 5-600 miles and it should last you 20k miles.
    If loud pipes save lives, imagine what learning to ride would do.
    Woooooosta
    Re: Chain question
    Yea this one lasted 18k, put it on the dyno and this is how it came out.
    I can def feel the power increase now even with the stock gearing. Feels so much better.
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Re: Chain question
    a At least eyeball the rear sprocket make sure it is running true
    check the chain after a couple hundred miles.
    Glen Beck is John the Baptist
    Woooooosta
    Re: Chain question
    yea the rear sprocket seems alright, the chain does move side to side at one point for like maybe 1mm or 2 but nothing major.
    Re: Chain question
    didnt know a chain could get 95+ hp on a dyno
    imagine what the engine would get
    Woooooosta
    Re: Chain question
    haha yea at least 300+ right Jim? Now imagine if i had the new chain and sprockets on there how much id get. Im losing between 5-10hp on there.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Re: Chain question
    Do you have the alignment correct?
    Re: Chain question
    Quote Originally Posted by bluej511 View Post
    Yea this one lasted 18k, put it on the dyno and this is how it came out...
    Jesus! Seized links much?
    Take care of your chain an it'll go 30,000 plus.
  1. Another Chain Help Question
    By idratherberidin in forum Bike Maintenance
    Last Post: 06-12-08, 12:50 PM
  2. Chain Question
    Last Post: 04-02-07, 12:39 PM
  3. Chain question
    Last Post: 01-05-06, 03:57 PM
  4. CHAIN QUESTION??
    By JJ in forum General Bike Related
    Last Post: 07-24-03, 04:51 PM
  5. chain question
    By oreo_n2 in forum Bike Maintenance
    Last Post: 04-10-03, 06:02 PM
