Results 1 to 6 of 6
Chain tool advice
    Lynnfield,MA 01940
    Chain tool advice
    First timer going to replace 530 chain and sprockets. Advice appreciated on best way to go on chain tools.
    Apr 2008
    Boston, MA
    Re: Chain tool advice
    Find someone local who will let you borrow their chain tool. I have the motion pro which works fine but was kinda pricey for what it is (~$100). Tips: loosen the front sprocket nut before cutting the chain. Generally I just use a dremel to cut chains but if you need to break it properly grind the end before using the breaker..
    Lynnfield,MA 01940
    Quote Originally Posted by GNTurbo6 View Post
    The vfr has 23000 miles , original chain. This might be the only time I use this tool in 5 years , borrowing sounds good. I was looking at the rk chain tool on sprocket center.
    Yeah to loosen the front sprocket it is easier to put the bike in gear and have someone hold the rear wheel or get an impact gun. The impact makes everything 3 million times easier, but you need a decent compressor and the gun.
    Posting Freak Puppet's Avatar
    Oct 2004
    Seattle Area
    Quote Originally Posted by viffer57 View Post
    The RK tool is great. Mine has been awesome and I know a few others that have been using it without a problem for years. Highly recommend. I have heard some not-so-great reviews about the Motion Pro chain tools in the same price range. Their Pro level stuff, however, is supposed to be pretty good.
    Brian
    LRRS/CCS EX #881
    WMRRA EX #281
    Steps for removal...
    1. grind down 2 pins on a link. (MOST IMPORTANT or you will mess up someones tool up)
    http://www.youtube.com/watch?v=ygJZu...eature=related
  1. DID chain tool for $60
    By Charlief in forum General Bike Related
    Last Post: 12-09-10, 09:39 PM
  2. Chain tool?
    By Awesome in forum Bike Maintenance
    Last Post: 10-18-09, 09:05 PM
  3. In need of a chain tool
    By nerijusj in forum Bike Maintenance
    Last Post: 08-05-07, 07:07 AM
  4. Chain Tool?
    By Honclfibr in forum Bike Maintenance
    Last Post: 03-10-04, 12:29 PM
