Results 1 to 25 of 34
changing oil
    Member motocrossnut00's Avatar
    Jan 2009
    changing oil
    I never find my self posting on this sight so thought i would post this quick lil question. I was just wondering after how many miles do u guys change your oil on just regular, is it every 2000 miles or 3000?
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Re: changing oil
    I used to change 2 times a year regardless of mileage
    Spring fresh synthetic for the season
    Fall Dyno oil before the big winter sleep
    Glen Beck is John the Baptist
    Jan 2009
    Waltham
    Wirelessly posted (Tilt: HTC-8900/1.2 Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.11) UP.Link/6.3.1.20.06.3.1.20.0)
    every 2500 for me, mobile 1 biznatch.
    Ps the highway is for going fast, ya granny
    Beantown Stan's Avatar
    Needham, MA
    Re: changing oil
    I change mine every 3000 with Mobil 1 fully synthetic.. I also change it before I put it away for the winter and also when the seasons starts up Ill change it..
    Mike (Stan) Facebook username = MJStanley508
    2006 Suzuki GSXR 600
    Yoshi R-55 Slip-on, PUIG rear hugger, PUIG windscreen, Pazzo levers, 6k HID kit
    Re: changing oil
    every 3500-4000 miles as recommended in my owners manual, no more, no less
    Just Registered drop's Avatar
    Bradford, MA
    Re: changing oil
    i drain and refill with rotella t 15w40 every 3000 miles. filter is replaced with an OEM on every other oil change (6000 miles).
    - Jamie
    2009 K 1300 S
    NorthShore
    Re: changing oil
    You guys using motorcycle-specific SG/SH/SJ oils, or CI4/SM Rotella HDEO and Mobil1?
    Needham, MA
    Re: changing oil
    Quote Originally Posted by toocrazy2yoo View Post
    I use motorcycle specific called Mobil 1 4T fully synthetic comes in black quarts
    Senior Member Pestilence's Avatar
    Salem MA - Soon.. Sandy Eggo CA!!!
    Re: changing oil
    Every 5 hours or 300 miles whichever comes first w/Rotella T
    Filters every 3rd change, I have 3 of them, 1 media 2 steel screens.
    -John
    "It's more fun to ride a slow bike fast,.. than to ride a fast bike slow."
    07 Husky SM510R
    Sep 2007
    Middlebury VT
    Re: changing oil
    Oil filter, per the manual is done every second oil change.
    Engine oil is done once in the spring and once before storage.
    My old bike seems to shift just fine regardless of the brand or type of oil used.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Re: changing oil
    I never change my engine oil. TZ's are good for the enviroment. No disposal issues with waste products.
    who knows
    Re: changing oil
    Just look at the owners manual of your bike!! It might be different than this but my RR says the same thing! every 4k
    And I plan on changing it before i put it away for the winter too!
    Quote Originally Posted by richw View Post
    What is this Dyno Oil?? Is it specially made for winter storage? What are the benifits over regular oil for winter?
    Re: changing oil
    I think that by dyno oil he is maybe referring to non-synthetic? Maybe? Not?
    Dean
    Central Mass
    Re: changing oil
    Listen to 'drop' and 'scubasteverr'. You don't need to spend alot on oil and filter. Rotella (blue can), super tech (filter), every 3K and before storing for the winter.
    Dean
    Aug 2004
    Baltic,CT
    Re: changing oil
    DYNO for dinosaur as in natural based lubricants non synthetics
    Old theory that petroleum is dinosaur blubber he he he he science is fashion
    ANY reasonable oil can winter over as the point is to provide fresh anti corrosion etc. for storage, and to drain combustion products, No sense spending $$$ for oil I am going to drain after a total of 300 miles or so. I also add "FOGGING OIL" to crank and full gas tank so there is an anti corrosion vapor coating. <<< real not a foreskin snype hunt
    who knows
    Re: changing oil
    I see what you mean with the DYNO oil no need to spend $10 a quart for Honda Synthetic for the winter... Do you start the bike up during the winter to warm up the oil and the engine and keep things lubricated instead of letting the oil just sit there covering only half your engine. And how often do you start it up if you do?
    and FOGGING OIL? no what the hell is this? and oil/gas additive... something like Lucas oil?
    Re: changing oil
    i change the oil every 3000 miles and the filter every 6000 miles, as directed by the service manual.
    Not mentioning what brand, weight, or blend I use because every oil thread turns into 60 pages of opinions.
    Aug 2004
    Baltic,CT
    Re: changing oil
    Fogging oil is a product usually used in marine engines specifically to winter them or store for long periods. It paints a sticky oil on the metal that sorta drys on the surface preventing rust mostly. ( I have gotten it at walmart)
    The classic is to squirt a good shot into the crankcase and gas tank.
    Then here comes the fun part
    Warm up the engine (really warm so there is no condensation in there) and then with throttle tweaking keep her lit while you spray the fogging oil down the carburetor(S) until smoke pours out the exhaust then you add while deceasing the throttle enough to eventually snuff out the engine,
    Wal La all the metal has a nice coating of sticky clingy rust preventative oil on it.
    Things like my rototiller with a squirt of ether happily start after 3 years storage outside.
    My injected motorcycle version is just like 1 or 2 oz in gas (completely filled) and crank case new oil then run take a 10 minute ride so she'd hot. Put her away maybe a squirt into the exhaust. If near vermin stopper or rag the exhaust
    Yes there are left handed monkey wrenches
    Dublin, NH
    Re: changing oil
    It's Dino, not Dyno. It isn't HP calculator oil. Common mistake for somewhat vague slang.
    Whatever the case, I change it every 3k with Rotella T synth.
    2023 KTM 890 Adventure R
    Jan 2009
    Re: changing oil
    i herd your spoced to change filter every time, well that's just what ill probably do their not that expensive anyhow. I already put over 2100 miles on the bike, the oil change was probably like 1800 ago or somethng , maybe ill do it soon for the hell of it, because ill be riding untill the first snow flake and then w,e its dry anyhow.
    May 2007
    Southern NH
    Re: changing oil
    People change oil way more ofen than needed....with synthetic oil 5-7 k under normal use is fine. More than fine actually.
    The 3k number bandied about is so old and out of date it's laughable! But old traditions die hard!
    I like to change mine at 5k just because the interval is easy to remember.
    Muhammad Ali.
    Jan 2009
    Middletown, Ct.
    Re: changing oil
    [QUOTE=DucDave;750584]People change oil way more ofen than needed....with synthetic oil 5-7 k under normal use is fine. More than fine actually.
    QUOTE]
    Car and Bike, 300, 1,000, 3,000, 5,000 then every 5,000. Filter and Washer everytime because for an extra $10.00 why not.
    who knows
    Re: changing oil
    [QUOTE=drinkingmymilk;750587]
    QUOTE]
    I do it similar for my 200,000k mile plus 03 Civic, although I do it between 7,500 - 10,000k miles and I have always used Mobile 1 since the breakin period (used Honda Oil the first 3). She runs like a dream still!
    I've only changed the bike once since i just bought it. I was planning on going 5k with the bike since redline is so MUCH higher than the car i feel this is going to break down the oil a little faster (civic 7k - RR 14k redline..)
    Replace the filter and the washer everytime and ALWAYS use a tourqe wrench to make sure the washer is properly set!
    Feb 2008
    Devon/Surrey, England
    Re: changing oil
    every 6k, along with the filter.
    NorthShore
    Re: changing oil
    Quote Originally Posted by DBKromz View Post
    Oh go on, give it up.. What's your secret?
  1. Tire changing - S/E NH or S ME ?
    By scootertrash in forum Bike Maintenance
    Last Post: 05-11-11, 07:39 AM
  2. Changing Gearing on 6th Gen
    By NeverlosT in forum General Bike Related
    Last Post: 01-31-09, 10:15 AM
  3. Tire Changing
    By dco8415 in forum General Bike Related
    Last Post: 06-20-07, 01:27 AM
