Results 1 to 7 of 7
Starter button piece?
    Member QuincyGixxer's Avatar
    Brighton, MA
    I've had a problem recently where my headlights just stop working (Hi's, Lo's, everything). I took apart the whole starter case on the right bar and found that the piece of metal that's embedded in the plastic of the actual button is bent on one side, so it fails to complete the circuits for lights/starter.
    I've bent the metal back and as long as there's pressure pushing down on the connections from above (stuck some folded paper and electric tape in there), it works.
    Does anyone have a spare piece I could buy, or know where I could get one without buying a whole new setup?
    (I'll post up some pictures, since my description sucks - pictures are now attached)
    Re: Starter button piece?
    that left side assembly sells for dirt cheap on the WERA forums. maybe like $10.
    but if anyone here has one, you might want to post the year GSXR. looking at your avatar, i'm guessing 05?
    Brighton, MA
    Ah, stupid! Yeah, it's an '05 750.
    I have all the parts U need.....I actually have a mint housing minus the inster for the Bar end that keeps it from moving around....and I would do a quarter turn throttle while Ur in there....I have one or two others in ok shape too.....all for an 06-07 600/750/1000
    Shawn 978-944-5163 saved U a PM also....
    OGH 05 may be Diff..........but Ill ask my 2 other buds they have 05's and I have a 4 bolt Vortex Gas cap for that also.....cheap
    shawn, stock is 1/4 turn, you mean a 1/5th turn. If you want to really shorten your throw, i have a brand new 1/6th throw throttle tube available.
    Brighton, MA
    I have no idea what you guys are talking about
  1. Replies: 9
    Last Post: 05-07-13, 05:43 PM
  2. The Opposite of Thank You Button
    By BLACK SQUIRREL in forum Site Info & Suggestions
    Last Post: 07-06-11, 03:19 PM
  3. Button Kits
    By Rye in forum Bike Maintenance
    Last Post: 07-29-05, 07:09 AM
