Results 1 to 17 of 17
Cleaning fuel injectors
    Mar 2007
    Andover, Ma
    Can anyone recommend a good place to have mine cleaned? I know there are plenty of DIY methods but I would just rather use a pro and be done so I don't have to worry. Close is good - I am in Andover.
    Re: Cleaning fuel injectors
    Proflow Technologies
    Mine have always come back within a week
    Lifer Stromper's Avatar
    Eastern Ct
    Is there a tune uppy difference or more just maintainence
    The calculus of hate
    Mar 2007
    Andover, Ma
    Dunno but this bike sat for a lot of years - last registered in 04 as near as I can tell. I have cleaned out plenty of carbs and I am thinking injectors have even smaller tolerances.
    The bike seemed to run and start fine but I just rode it around my house a little - no real road riding. I have it all apart as a winter project and want to make sure its ready come spring.
    So to answer your question... yes.
    Proflow, like bergs says. They will clean and balance them and send them back with a report.
    +1 and they did mine and was spot on and few day turn around....
    How do they balance them? I have heard of checking the flow of many sets and matching up like ones, but that was with more common car injectors.
    FWIW and doesn't replace service. I traded emails with a Yamaha engineer and asked him at one point about fuel treatment. He recommended Techron: apparently their Ring Free additive is similar.
    They run the injectors for a standard amount of time and catch the gas, and measure them in Graduated Glass Cylinders....and adj as needed. And a huge part of his business is Car injectors wich they do also...same means of cleaning, testing and atomizing
    Meriden, Ct
    I've tossed a bottle of Ring Free into everything with a tank, every spring, for years. It was at the advise of a Suzuki engineer... Recommending a Yamaha product.
    If they've never been cleaned, yes. After that, yes.
    I have only sent them out for my race bike but appreciated the confirmation of injector health after the fact.
    Okay, I know I'm being picky about semantics, but I want to know if there's something I'm missing.
    I understand cleaning by ultrasonic/solvent/flow/heat methods. Makes sense to change the inlet screen and O-ring. I get flow testing (measured volume over time) and checking the spray pattern before and after cleaning. I've never heard of an adjustable injector. AFAIK they are just a solenoid that opens. You can increase fuel pressure or duty cycle to increase flow, or install larger injectors. I didn't see any mention of adjustment on the ProFlow website. Someone help me out here, how are they being balanced and or adjusted to match each other? I don't think they are, they're just being cleaned to meet a factory acceptable range.
    I believe they just run them after cleaning. If they are within acceptable tolerances, good. If not, replace them.
    What does a service like this cost? I only have 2.
    Eastern Ct
    The injectors are electro MECHANICAL devices
    There may be a considerable difference in how fast or how much they open
    I could imagine
    putting them on a cleaning rail.
    Then checking them, and only if they do NOT perform maybe taking them apart for a tune up/polishing
    Maybe lapping the valve seat etc.
    I would talk with them first but the level of service I go for ends up being about $20 per injector
    I could imagine
    in my experience, they usually come back within 3-5% of each other. Any more than that and they would replace. I highly doubt they are taking apart a fuel injector and lapping the valve seat.
  1. Cleaning out the toy box sale!
    By R7 in forum For Sale
    Last Post: 12-18-12, 08:30 PM
  2. ex250 w/ stage 3 injectors
    By Marc R in forum General Bike Related
    Last Post: 03-01-12, 05:28 AM
  3. matched injectors
    By double agent in forum Bike Maintenance
    Last Post: 01-29-05, 02:46 PM
