Results 1 to 14 of 14
Cleaning stainless exhaust pipe
    Redistribution Supplier
    So I had to use exhaust sealant on my last exhaust due to a small leak.Apparently this stuff melted with the heat and stated running down the y-pipe.It's kind of like soap stains.
    Any tips on cleaning this ?
    Tried Simple Green,WD40 so far with no results.
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    Re: Cleaning stainless exhaust pipe
    Try "goof off" with a green scour pad. Then follow up with mothers metal polish paste. The goof off should get it off and the polish will make it nice and sparkly.
    Lancaster
    Wirelessly posted
    Buffing wheel
    Corey
    Thanks,I'll try the Goof Off..Don't really care about it shining I just want the stains off.
    Roslindale, MA
    WD and a little elbow grease with scotchbrite.
    Member gt_pedaler's Avatar
    Lowell
    find some spray on Kaboom. spray in on when a little warm, not ho and then rinse off. look like new.
    Thayer
    Cape Cod Metal Polishing Cloths FTW!
    http://www.capecodpolish.com/products/main_index.php
    Bar Keepers Friend does magic on stainless steel.
    Two many 2 strokes
    Bradenton FL
    Fast orange hand cleaner with pumice....amazing....and smells good LOL... removes rust from chrome like nothing else! You will thank me!
    001 Stainless steel wool and some windex.......Windex makes chrome glow and there is some polish called White Diamond also to finish it up with and nice polish and wax and wipe......done
    I ended up using some oven cleaner after trying Goof Off,steel wool,Simple Green and just about every other cleaner I had lying around.
    I put the Y-Pipe in the oven for a bit then sprayed the oven cleaner on(Fumes caught me by surprise and were pretty bad) and let it set for a while,then used a Scotch Brite pad and scrubbed the hell out of it.Results were what I wanted and has the brushed stainless look again,almost perfectly matches the pipes on the new Akrapovic slip-ons I bought.
    Thanks for all the suggestions.
    Expert Agitator
    Ashford, CT
    Good to know. You just used regular old Easy-Off oven cleaner?
    Ya,though if I had to do it again I would get the version of oven cleaner that you can use in a cold oven.
    The fumes were pretty bad,I thought I was going to pass out...I think the regular oven cleaner needs a lot of heat for the chemicals to do their thing.
    We used to use oven cleaner to remove lettering from Vans and trucks also.........then buff and go
  1. Replies: 1
    Last Post: 08-23-11, 09:00 PM
  2. Need a hand finding an exhaust pipe heel guard
    By Quigs in forum General Bike Related
    Last Post: 05-17-08, 06:17 AM
  3. Pipe cleaning?
    By OreoGaborio in forum Off-Topic
    Last Post: 07-11-05, 06:13 PM
  4. Stainless exhaust valve regrind
    Last Post: 11-27-04, 09:31 PM
  5. Stainless exhaust hardware?
    By Honclfibr in forum Off-Topic
    Last Post: 06-11-04, 04:51 PM
