Results 1 to 4 of 4
New clutch cable issues
    soldier medic neuthunder's Avatar
    Jul 2005
    boston/abington
    So i put the new clutch cable on and road for a little bit to break it in. then i started to push the bike and next thing i know the bike was jumping out of gear. under hard acceleration in second gear it'll be climbing up to about 8-9k and the bike will come out into neutral. this has happened about 3 times. Could this just be from the new cable breaking in?(fingers crossed) or is this a larger issue?
    If you're popping out of gear, it's probably not a clutch cable Sounds like shift forks or whatever the part is that holds the gear in the transmission?
    do you have the proper amount of freeplay in the cable? did you have this problem before you changed the cable? freeplay should be enough to put the edge of a nickel between the lever and the perch without pulling on the cable
    Jul 2005
    boston/abington
    well the perch isnt exactly the best but there's more than enough free play right now.
  1. WTB clutch cable asap
    By Wishbone in forum Wanted
    Last Post: 04-06-10, 06:52 AM
  2. anyone have a YZF 600R Clutch Cable
    By reiobard in forum General Bike Related
    Last Post: 09-07-07, 12:13 PM
  3. Clutch cable?
    Last Post: 08-09-07, 03:29 PM
  4. HELP ! CLUTCH LEVER/CABLE ISSUES!
    By 01YZF6 in forum Bike Maintenance
    Last Post: 10-09-05, 10:25 PM
  5. clutch cable
    By neuthunder in forum Bike Maintenance
    Last Post: 07-25-05, 05:50 PM
